Tensioner Pulley Help
Old May 12, 2011 | 07:15 PM
350pandaz's Avatar
350pandaz
Default Tensioner Pulley Help
I have a problem with my A/C tension pulley. I've searched for a couple weeks now and im forced to lean on my fellow forum buddies.
heres the situation, changed belts a couple weeks ago and found out my A/C tensioner pulley bolt's head has been broken off by previous owner. looks like he/she decided to take a crow bar and pry it toward the passenger side to try and tighten the belt. I guess it worked but after i got the crank belt changed, the A/C side decided to squeel like crazy when the A/C is on.
Has anyone changed the whole tensioner before? Does anyone have a DIY on it? Any recommendation would be greatly appreciated. thanks in advance!
Old May 13, 2011 | 06:54 AM
str8dum1's Avatar
str8dum1
the tensioner is just bolted to the bolt. easy swap.
Old May 13, 2011 | 08:30 AM
350pandaz's Avatar
350pandaz
The bolt ur referring to, is that the one that adjusts the tension? If so, does it just screw right off? Thanks
Old May 13, 2011 | 10:25 AM
str8dum1's Avatar
str8dum1
i thought you were talking about replacing the entire tensioner. the entire tensioner comes off.
the long bolt that adjusts the tension can also be replaced. you'd need to figure the thread pitch and order one from like mcmaster carr or fastenal.
Old May 13, 2011 | 11:04 AM
350pandaz's Avatar
350pandaz
I could go either way, I'd rather replace the whole assembly just because I would most liking have trouble getting the adjusting bolt off since it's broken an bent.
lapham3
Oct 7, 2022 03:15 PM
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
