Help with Brake Problem
Old Jun 4, 2011 | 02:13 PM
lax91181's Avatar
lax91181
Default Help with Brake Problem
I replaced the pads and rotors on the rear and the driver's side rear brakes make a smell and produce a crazy amount of heat. This does not happen all the time but it does happen. After the brake job when I first noticed the problem I took the caliper and pads back off and cleaned everything down and greased up the pins. This helped and no problems for a few days, then the smell and heat came back. It keeps coming and going, day to day. I have yet to hear any noise or feel any shimmys. Any ideas on what to try to fix? I am sure that I am quickly wearing my new pads and rotors. Thanks!
Old Jun 4, 2011 | 04:04 PM
DavesZ#3's Avatar
DavesZ#3
Did you bed-in the new pads/rotors?
Old Jun 5, 2011 | 06:01 AM
lax91181's Avatar
lax91181
Yes, I did. The passenger rear is fine, it is only the driver side causing the problem.
Old Jun 5, 2011 | 07:30 AM
winchman's Avatar
winchman
The piston is probably jamming in the caliper, causing the brake to drag continuously.
Uriyo_
Sep 8, 2021 08:46 AM
