sticky throttle/ still revs when i put clutch in
Old Jul 8, 2011 | 11:41 PM
ejs0806's Avatar
ejs0806
Default sticky throttle/ still revs when i put clutch in
My throttle has like i would explain it as a lag. When i push the clutch in to change gears rpms still go up for alittle then drop down like they should. NO IM NOT RIDING THE CLUTCH AND KEEPING MY FOOT ON THE THROTTLE.. A friend mentioned having the ecu relearn throttle positioning... Anyone have similair problems or anything and know how to fix it.. Im afriad im doing uneeded damage to my clutch as well as some rough shifting because rpms just start to drop when i let the clutch out when i grab the next gear so its a little jerkey.. I thought it was just the way it was but i drove another Z the other day and noticed its not.. Thanks guys!
Old Jul 8, 2011 | 11:58 PM
JPsZ's Avatar
JPsZ
http://www.motordyneengineering.com/manual.pdf
go to page 9. Use the 2nd procedure on that page.
Old Jul 9, 2011 | 12:08 AM
When you engage the clutch engine RPM will drop. You just added the drive train load to the motor.
Old Jul 9, 2011 | 09:58 AM
ejs0806's Avatar
ejs0806
Thanks gunna try that today
Old Jul 9, 2011 | 10:01 AM
ejs0806's Avatar
ejs0806
It will still continue to rev a few hundred rpm then drop. Which isnt normal
sherm
Apr 11, 2020 05:21 PM
