Battery Sparking big problem!!!!
Old Jul 9, 2011 | 07:56 PM
sjthegreat1's Avatar
sjthegreat1
Default Battery Sparking big problem!!!!
Hey guys i need help. Its Arcing!!I just replaced my engine and now im conecting the battery and it is causing huge sparks and burning the terminal. I have just bought a new battery so that cant be it. I checked all connectors and they seem to be clean. I disconnected most of the connectors on the radiator support and engine and it still happens. I checked my grounds and everything seems fine also. Please guys help!!!
Old Jul 9, 2011 | 08:32 PM
winchman's Avatar
winchman
Check the wire going to the starter. If it's connected to the wrong terminal or shorted to ground somewhere, it would cause arcing when you try to connect the battery. Everything else goes through fuses that would blow if the circuit is shorted. The starter is on a fusible link that will carry much more current.
Old Jul 9, 2011 | 11:27 PM
bbs350z's Avatar
bbs350z
check the starter, itll fry violently if hooked up wrong
Old Jul 10, 2011 | 02:29 AM
winchman's Avatar
winchman
^^^ what he said.
Old Jul 10, 2011 | 12:01 PM
sjthegreat1
I disconected the alternator completely and it doesnt do it anymore. Does this mean the alternator is bad or the wires?
Old Jul 10, 2011 | 01:18 PM
Cass007's Avatar
Cass007
Make sure you have the big ground connected correctly from the chassis to the alternator then to the starter.
Old Jul 10, 2011 | 11:27 PM
bbs350z's Avatar
bbs350z
^what cass said. i believe it connects on the back terminal of the alternator
Old Jul 11, 2011 | 12:05 AM
sjthegreat1
fixed it!
Old Jul 11, 2011 | 12:23 AM
midz350's Avatar
midz350
^^ How?
To help people in the future.
Uriyo_
Sep 8, 2021 08:46 AM
