Fuel pump wont run??
Ok guys, i am confused at what could be wrong... Went ou and started the car this morning, backed it up into a different spot, shut car off...a few hours later i went and started it again, ran for about 2 seconds then died...tryed to restart it and it just turns over....listened for my fuel pump to prime the system and nothing....checked fuses, relay, and even pulled my aftermarket pump out and put the stock one back in, still nothing.
When i put the car on "ON" the fan turns on tho?? Someone said it could be a key problem? Maybe something with the stock theft system?
I am clueless guys...please help me out!!!
any updates?
I have the EXACT SAME problem. I had the HKS DlI installed and it wouldn't stay running. Now, the car will crank but not start, the Fuel pump doesn't start priming at all... checked the fuses relays and wiring... still all good
what did you find as the fix?
someone said i fried my ECU... before shelling out $400 for a replacement, that i think is not a root cause, i'm wondering how you worked it out.
any updates?
