70k miles on 04, what to do?
Old Jul 24, 2011 | 11:17 PM
Mcutali's Avatar
Mcutali
Originally Posted by DaveJackson
^HA!
This reads a bit like you've only changed your oil twice!
well guy either way im 2nd owner, bought the car with less than 40k it was 70k the diff fluid has been changed exactly three times now and the tranny twice. now as for the oil probably 10x. so sorry if i mislead anyone
Old Jul 24, 2011 | 11:20 PM
Mcutali's Avatar
Mcutali
Question new z owner.
Originally Posted by briin79
You nailed it right on the head of pretty much what i was looking to hear. good advice from all. didnt understand really what the rear bushings guy was saying. I will have the tranny fluid swapped out and clean the TB.
I am in the same boat about hoses. the belts were replaced because of major wear.
lol look under the rear of your car... if you see a big ol leak from a rubber bushing in your subframe...nissans going to tell you 1100+ dollars for new subframe...and your best bet is solid bushing for a fraction of the cost, its a bs install and process....but it has to happen eventually. remove your sixth cyclinder coil pack, theres 1 10mm bolt holding it on and a delphi connection, remove them and check inside the spark plug tube for oil its a known issue, do you understand now?
Old Jul 24, 2011 | 11:58 PM
billsrcursed's Avatar
billsrcursed
Why so much on the diff. and tranny fluids??
Old Aug 3, 2011 | 01:42 PM
Bevo's Avatar
Bevo
Originally Posted by Bret86944
Probably a good idea to change your coolant.
Why the plugs? I can't remember offhand but I thought the stockers would good for like 75 to 100k miles?
For the plugs, the book says change it at 105,000 miles.
Old Aug 3, 2011 | 01:54 PM
e46330i's Avatar
e46330i
The book says so, but you'll probably want to change them closer to every 60k miles. 75k is around the time most people swap them out.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
