Window Motor Switching?
Old Jul 22, 2011 | 07:27 AM
350ZTuner018's Avatar
350ZTuner018
Default Window Motor Switching?
Ok heres my problem haha. My window motor has been giving me problems the past few days and I Plan on replacing it. But im going on vacation tomorrow morning at 6am so I cant get the part until I come back. I have a 4 hour drive going through many tolls and I dont want to be stuck with a window that cant go down for the entire ride. I dont need my passenger window open so is it possible to take the motor from the passenger side and put it on the driver side until I get home? or do they operate in reverse? This might be a stupid question but i figure its better to be safe then sorry. Thanks guys!!
Old Jul 22, 2011 | 07:49 AM
ericjackson's Avatar
ericjackson
i think they are 2 separate part numbers and i dont think it will work. but there may be someone that can confirm
Old Jul 22, 2011 | 08:44 AM
AJCaron12's Avatar
AJCaron12
What is it doing? Do a search for "window motor reset."
Old Jul 22, 2011 | 09:44 AM
350ZTuner018
well It wasn't working at all so i cleaned it out and made the connection better. Now it works sometimes but i have to keep hitting the window and fiddling with it to make it roll up all the way or down all the way. my main issue is that i will be away at lake george NY all weekend with no tools and its supposed to rain a few days. I dont want to be stuck with a half open window lol. I am going to do the reset in about an hour ill let you know if that works. But i would rather have the driver side working properly.
Old Jul 22, 2011 | 10:48 AM
green_bread's Avatar
green_bread
You will not be able to use the passenger side motor because of the way it mounts to the cable spool and door. I wish this was possible as my drivers side window hasnt worked since the day I bought my Z. I finally found a reasonably priced replacement and will be installing it as soon as we get a day thats below 100 degree heat index here in Missouri.
Old Jul 22, 2011 | 11:08 AM
350ZTuner018
ah damn. Thank you everyone for your knowledge. and I know what you mean about the 100 degree mark. I live in NJ and its 106 here right now lol. its brutal. Working on any car in this heat is out of control.
Old Jul 22, 2011 | 02:37 PM
ndilo21's Avatar
ndilo21
I'll be up in Lake George on Sun/ Mon and could lend you some tools. I had the same problem on my motor. I cleaned it once and it started sticking again so when I cleaned it the second time I used sandpaper on the connection points and it hasn't given me issues since. Are you going up for log bay day?
Fixxxercask
Nov 9, 2015 11:10 AM
