Engine Trouble Code Help
Old Aug 4, 2011 | 01:21 PM
ljt.350z's Avatar
ljt.350z
Default Engine Trouble Code Help
Hey guys, what should I do? I took my 07 350z to auto zone because my service engine light came on here are the codes that they gave me P2A03 and P0420. Are the codes bad and what does it mean? Thanks
Old Aug 4, 2011 | 01:27 PM
kham25's Avatar
kham25
Why did'nt you ask them what the codes meant when they pulled them ?
Old Aug 4, 2011 | 01:29 PM
DavesZ#3's Avatar
DavesZ#3
Moved to proper forum
That's odd because usually Autozone gives you a slip of paper with the codes and explanations on it.
You can look up codes here..
https://my350z.com/forum/maintenance...d-generic.html
Both are related to emissions...
P2A03 A/F Sensor 1 Bank 2 Circuit Range/Performance
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
It's odd that they are on different sides of the car (bank 1 vs 2).
Old Aug 4, 2011 | 01:42 PM
ljt.350z's Avatar
ljt.350z
Sorry, P0420 can be
- Large vacuum leak
-Fuel system fault
-Ignition system fault
-Failed bank 1 catalytic converter
P2A03 can be
-Intake air leak
-High fuel pressure or leaking injector
- Af ratio sensor heater circuit fault
-failer af sensor
I'm new at it, so I don't know if its bad or not. I have no mods the only thing is a kenwood head unit.
Old Aug 4, 2011 | 01:55 PM
DavesZ#3's Avatar
DavesZ#3
Have you done any work to the car before this problem came up?
Old Aug 4, 2011 | 03:08 PM
ljt.350z's Avatar
ljt.350z
No, I haven't done any. I am not the first owner either.
Old Aug 4, 2011 | 03:37 PM
ljt.350z's Avatar
ljt.350z
Is that true that Nissan would replace your cats converter if your car has under 80,000 miles by federal law? Mine is at 49K. Thanks
Old Aug 4, 2011 | 04:05 PM
Waiz's Avatar
Waiz
Thread title edited.... please title your threads according to the relevant content included
If there are no warning signs other than the codes I would suggest that you visit a local mechanic to properly diagnose your issue.
Old Aug 4, 2011 | 04:08 PM
ljt.350z's Avatar
ljt.350z
Thanks guys
Old Aug 5, 2011 | 03:32 AM
DavesZ#3's Avatar
DavesZ#3
Yes, I just had one of mine replaced at 57K miles on a 7½ year old car.
Old Aug 6, 2011 | 05:24 PM
ljt.350z's Avatar
ljt.350z
I took my car to the dealership, and it was the catalyst. Thanks guys for all your help!
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
