SLIP / TCS light comes on and ignition problem
Old Aug 6, 2011 | 03:44 AM
blue262's Avatar
blue262
Exclamation SLIP / TCS light comes on (solved) and ignition problem
Hi all,,
I have 2 problems
1st: ((SOLVED))
The SLIP / TCS light comes on the moment I start driving / rolling the car out of the driveway.
Sometime I can feel the slip / tcs kick in like crazy! (similar to abs kicking in).
Sometime only the lights comes on with no sign of it kicking in.
After both lights come on I can't switch on/off the TCS
and (TCS off) light remains on till I restart th car
Solution: I have checked the car using Consult II and C1143 Code appeared
its for ((Steering Angle Sensor))
and all I needed is reset the steering angel using Consult II (steps are attached))
SLIP / TCS light comes on and ignition problem-sangle.jpg
2nd:
The car doesn't start fast as the others! the ignition takes few seconds to start the engine spacially when the car is hot!
the battery and battery wiers are fine and the ar starts normaly when its cold (morning time)
Can anyone give me some solutions for this ??
the light is getting very annoying and I want to get it fixed and the starting makes m emmbaress asap
Old Aug 6, 2011 | 04:54 AM
DavesZ#3's Avatar
DavesZ#3
1) Have you changed tires recently? Read this... https://my350z.com/forum/showthread....1&postcount=45
Done any work on the brakes, wheels or suspension?
2) Weak battery.
Old Aug 6, 2011 | 11:08 AM
blue262's Avatar
blue262
2) Weak battery.
I have this problem ong time ago,, I've bought the car from someone and the problem was there
Its comming originally with 18" and with different sizes rear and front
I used
19" blitz rimsl
17" original rims
and now with 18" Ray rims
the problem is same with all rims and tires
and nothing done with the suspension or brakes (it comes with brembos)
Old Aug 6, 2011 | 11:29 AM
DavesZ#3's Avatar
DavesZ#3
The problem could be in any one of the 4 wheel speed sensors. Or it could be a problem with the computer that controls TCS/ABS.
Old Aug 6, 2011 | 01:37 PM
amr_electron's Avatar
amr_electron
Originally Posted by blue262
Hi all,,
I have 2 problems
1st:
The exact same thing happened to me when i had a pretty worn brake pads, SLIP light & VDC OFF in my case.
Check your pads, rotors & brake fluid.
Old Aug 6, 2011 | 03:22 PM
blue262's Avatar
blue262
Every thing is good! and front just been replaced few days ago
and rear been replaced monthes ago
the problem is more than one year even before replacing the pads
But my ABS is functioning normal
Old Aug 6, 2011 | 03:27 PM
blue262's Avatar
blue262
about ignition problem:
my battery is good, it never comes morning time! only if the engine is warm!
could it be from crank sensor or camshaft sensor?
I have no SES related to that
I have only P1051 ((A/F Sensor Heater), is it left side front one?? Correct me if I'm wrong!
Old Aug 6, 2011 | 05:07 PM
DavesZ#3's Avatar
DavesZ#3
When the engine gets warm, so does the starter motor. The heat increases the resistance in the windings of the starter motor making it weaker and harder to turn over.
How do you know ABS is functioning properly? Is there a dealer nearby you can get the brake/TCS system tested ?
Old Aug 7, 2011 | 12:49 AM
blue262's Avatar
blue262
Old Aug 7, 2011 | 12:52 AM
blue262's Avatar
blue262
The sound of the starter is normal, fast and turns over as normal,, just the engine needs longer starter turns when it get warm,,
(I could know if its from the battery electrycity or starter)
when the battery is bad or starter is week, it becom slower and harder to turn over, but in my car it's some thing like the fuel is not there so it turns over and over for few seconds then get start. (I hope you got my point)
the light of ABS is off and while applynig hard brake its functiong normally
(I can feel it)
Old Aug 9, 2011 | 03:21 PM
blue262's Avatar
blue262
Old Aug 16, 2011 | 09:59 PM
blue262's Avatar
blue262
top to up
Old Aug 17, 2011 | 08:14 AM
CRIDDA's Avatar
CRIDDA
I had this problem and it was throwing codes for crank position sensor. Do you have CAI? Where do you live? I put my stock air box back on and cleared the codes(haven't had problems since). These hot *** temps we have been having in the south have been ******* with A/F ratios. check this other thread
https://my350z.com/forum/engine-and-...y-driving.html
Old Aug 18, 2011 | 04:42 PM
blue262's Avatar
blue262
Thanks for ur comment,, I have 2 broblems! which one r y talking about?
1st: TCS/SLIP light coms on few seconds after driving, then the TCS stuck at TCS off and I drive tha car normally as it is without TCS!
2nd: Ignition is slow while starting the enging, after the engine is stared I drive the car normally without any problems at all !!
but the problem in ur link is totally different than both I have !
Old Aug 28, 2011 | 07:13 AM
blue262's Avatar
blue262
1st: ((SOLVED))
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
