Leds cruise control
Old Aug 14, 2011 | 06:59 PM
ncis350z's Avatar
ncis350z
Default Leds cruise control
looked through some threads and I cant seem to find the answer im looking for but it did help me pin point some more things. I had leds in the back. I think it caused my cruise control to not work. It goes on, but the set light keeps blinking. Also I don't have all the power I should on cold days. I changed the lights back to stock, but I still have the lose of power and cruise control issue. Any help would be appreciated.
Old Aug 15, 2011 | 03:26 AM
DavesZ#3's Avatar
DavesZ#3
I know there is an issue with some LED tail lights that require the addition of a resistor, otherwise the car thinks the brakes are being applied, hence the power loss. If you re-installed your regular lights correctly, then the problem should go away.
Old Aug 28, 2011 | 07:01 AM
NissanTracker's Avatar
NissanTracker
having a similar problem but i have OEM tail lights..... not sure what to do. When this power loss occurs... does the VDC light up? Mine doesn't... i just get the power loss
-NissanTracker
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
350z82
Oct 1, 2015 06:25 PM
