help with draining coolant and refill
Old Aug 29, 2011 | 04:07 PM
350zbehold's Avatar
350zbehold
Default help with draining coolant and refill
hello my350z user. i will be changing the coolant on my 06 redline z for the first time. and i was just wondering that , can i just drain the fluid and refill with new coolant and dont have to remove or unscrew the heater bleed screw. i cant find or seem to know what is the purpose of remove that screw.
Old Aug 29, 2011 | 06:02 PM
terrasmak's Avatar
You can, but your not going to get all the air out of the system. Pass side back of the motor, heater line with a T in it, you need a large phillips head to remove it.
Old Aug 29, 2011 | 06:34 PM
350zbehold's Avatar
350zbehold
yes you right i found the the heater bleed screw...tomorrow before i go to work i will be buying the heater bleed screw......but by the way so how do i do this... any complete diy ... because i want to switch coolant just before i can do a long trip to vegas... so according to the diy i found i can drain the coolant after that remove the heater bleed screw . then after that replace the screw and replace the radiator cap and refill radiator with new coolant and after taht bleed the system by letting the car idle throught normal working temperature and then after it reach it normal temps. rev the engine to 3k rpm and hold it for about 10 second then after that shut off the car and let it absolutely cool down then refill ?
color me if i am missing something or you guys found a way to bleed the system faster
Old Aug 29, 2011 | 08:18 PM
DaveJackson's Avatar
DaveJackson
Master
You sound a little inexperienced and A LOT of folks have had an extremely tough time getting all of the air out after doing this job. Maybe I got lucky because I had zero problems, but if you don't nail this on the first try, you could get stranded on the way to Vegas.
If you're not fully confident on this, I just wouldn't risk it before a big trip. Try it when you get back.
Old Aug 29, 2011 | 10:16 PM
Mcutali's Avatar
Mcutali
Default here
jack the front up high as possibly higher than bleeder screw then all u need to do is keep rad cap off with car at idle with heat full bllast, for like 20 minutes you will see slow amounts of tiny bubbles make sure u got a beer to drink.
Old Aug 29, 2011 | 10:25 PM
sssmasss's Avatar
sssmasss
why dont you do backflush? i havent dont my but i did back flush on my vr4 and teg. all you need is a prestone flushing kit. i like the flushing idea because it is not cleaner. i refill with new coolant from nissan.
Old Aug 30, 2011 | 08:13 AM
Zazz93's Avatar
Zazz93
Bleeding the air is tough on the car, my only advice is watch the temps while your doing it, and don't assume things are going well at any point and leave it unattended.
+1 on the jacking up of the front end, I personally park on a steep incline to do it.
Old Sep 1, 2011 | 11:55 PM
350zbehold's Avatar
350zbehold
well i dont know how long is the last time the car had an coolant flush... because the car perform very well with AC on low setting and on 117 degree arizona heat the car have no problem...and i did alot of research the best bet it just to let the dealership did it . if anything goes they fix it and not me... because im planning to do it after the trip..i only live about 4 hours from vegas and i will be driving at night so it will be cooler..any more tip?
Old Sep 2, 2011 | 12:01 AM
Spork's Avatar
Spork
Coolant lets the HEAT work good, not the AC.
Old Sep 2, 2011 | 12:26 AM
JDMStanced's Avatar
JDMStanced
how often do you change the coolant?
Old Sep 2, 2011 | 08:35 AM
DaveJackson
Master
It's not that difficult to do once you get back, I just don't want to see you stranded on your way to Vegas if you screw it up.
When you get back, get a Factory Service Manual (FSM) and follow the directions precisely. It takes a while but then it's done and the coolant lasts for years.
IMO, adding the new coolant very very slowly (as it says in the manual) is an important step that I think a lot of people miss.
Old Sep 2, 2011 | 01:54 PM
Zazz93's Avatar
Zazz93
Honestly, I've not noticed a difference in adding the coolant slowly, or not. Its always been a P.I.T.A. But I did notice a substantial difference in bleeding the car high, on jackstands.
Old Sep 2, 2011 | 02:21 PM
RandyK1's Avatar
RandyK1
You need one of these Funnels http://www.amazon.com/gp/product/B001A4EAV0 its the best $20 you will ever spend. Search for threads on this funnel, you will see
Chris350z03
Oct 8, 2023 07:19 PM
burglapfd
Dec 6, 2020 01:04 PM
SharX59
Sep 27, 2015 09:23 AM
waldo36
Sep 20, 2015 09:13 PM
smithmt3
Sep 11, 2015 08:25 PM
