Car just died!!
Old Sep 2, 2011 | 02:34 PM
tally350z's Avatar
tally350z
Default Car just died!!
I was getting on the interstate to head to work and when I got up to about 70mph the car just died like it went into limp mode. I was able to pull over to the side of the road. I let the car sit for a few minutes and tried to crank it back up. It turnsover and then it just rumbles and then dies.
I am going to say it is the fuel pump, but wanted to get some of your guys opinions on the matter.
The car is basically stock, except for exhaust and intake, nothing else.
Old Sep 3, 2011 | 08:55 AM
tally350z's Avatar
tally350z
Anybody??
Update- the car now starts, but when you try and let it idle it has a rough idle then dies. If you give it gas then it seems to run normally but if you let go back to idle its rough and then dies.
Old Sep 3, 2011 | 09:24 AM
JaE35z's Avatar
JaE35z
throttle body maybe?
Old Sep 3, 2011 | 09:36 AM
terrasmak's Avatar
Did it throw a code ? Is the fuel pump coming on, what is the fuel pressure.
Old Sep 3, 2011 | 10:42 AM
0jiggy0's Avatar
0jiggy0
No one here has a magic ball. We need to know the basic checks.
Old Sep 3, 2011 | 05:06 PM
tally350z's Avatar
tally350z
Has a fairly new throttle body that was installed by the dealership maybe 8k miles ago.
Not throwing any codes.. Don't know what the fuel pressure is but from what I can hear it has pressure.
Not saying anyone has the answer, just wanted to get peoples opinions on the matter, if anyone has encountered this before.
Old Sep 5, 2011 | 11:22 AM
tally350z's Avatar
tally350z
Update: So I replaced the spark plugs and the old spark plugs were pretty worn down, but nothing shocking. I checked for a CEL and I got two codes P0305 and P0305pd, which is a Cylinder 5 Misfire.. So I guess this means that it can be narrowed down to either a Vacuum leak or possibly a bad coil?
Any input would be appreciated..
Old Sep 5, 2011 | 11:30 AM
ronn1's Avatar
ronn1
bad coil would be a good guess. Swap cyl 5 coil to another position and see if it misfires at new location. BINGO.
Old Sep 5, 2011 | 12:27 PM
tally350z's Avatar
tally350z
I swapped the coil and I didn't get the code on another cylinder. The car is still starting and then dying when it tries to idle.
Guess its back to the fuel pump or vacuum leak?
Old Sep 6, 2011 | 06:11 PM
zolaman8's Avatar
zolaman8
Research on crankshaft sensor. I had similar problem but not exactly.
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
