Calling those that have torn down the vq. Need help
Old Sep 4, 2011 | 02:18 PM
ericjackson's Avatar
ericjackson
Default Calling those that have torn down the vq. Need help
ok i am stuck. I have been following these series of threads https://my350z.com/forum/engine-driv...ing-chain.html
well i am trying to get the cam bolts out and they are a *****. the manual saiys they are torqued to 73-79 ft-lb but no way. Here are the bolts circled
My cresent wrech keeps flying off and im affraid im going to mess up the cams. Ive tried rolling the engine over and using a long breaker bar to hold the cresent wrech and use the ground as leverage while i yank on the bolt with my breaker bar but it popped the wrech off again. I am out of ideas to get it off. Anyone have issues with these? Also, can i just skip taking it off? I just need to get the heads off to have this engine worked on.
thanks
Old Sep 4, 2011 | 02:23 PM
0jiggy0's Avatar
0jiggy0
Id believe it. After a bunch of heatcycles and maybe loctite **** siezes up. Have you tryed an impact gun? The quick impact should break the nut.
Old Sep 4, 2011 | 02:28 PM
ericjackson
thanks, yeah ive tried one. i can get my hands on a better one because mine isnt quite as powerful
Old Sep 4, 2011 | 02:33 PM
k6750gsxr's Avatar
k6750gsxr
I usually just impact those off no problem. I would stop what your attempting because it looks like you are starting to roll the bolt flat.
Old Sep 4, 2011 | 02:40 PM
ericjackson
thanks. i may have to get my dad to bring by a better impact. and the bolts are still fine. if you are referring to the black on the bolt, its oil i picked up on the socket
Old Sep 4, 2011 | 02:56 PM
Italianjoe1's Avatar
Italianjoe1
Better tools needed IMO. A good wrench will get it, but the impact will work best and easiest.
Old Sep 4, 2011 | 03:26 PM
ericjackson
i agree i need a better impact gun. a good wrench would not make a difference. my kobalt wrench was popping off, but my craftsman actually rounded off one of the pieces of the camshaft.... is that bad?
at this point, with as much force as i used, i cant see an impact gun getting it either. but i can not think of another way
Old Sep 5, 2011 | 07:16 AM
DaveJackson's Avatar
DaveJackson
Master
Why are you using a crescent wrench for something that's so tight? That is your entire problem. An impact socket with six points of contact will remove that easily while your two points of contact will over stress the bolt head and destroy it.
Idk if these bolts use Loctite, but if they do, you'll need some heat to get it to unglue as well.
Old Sep 5, 2011 | 09:32 AM
ChuckW's Avatar
ChuckW
If you get that shrub out of the block, it will definitely run better!
Old Sep 5, 2011 | 10:29 AM
ericjackson
no, the crescent wrench is used to hold the cam from turning.
Old Sep 6, 2011 | 06:17 PM
ericjackson
well, i "rented" a 600 ft/lbs torque wrench from lowes, and with that and a blow torch i got them both free!
burglapfd
Dec 6, 2020 01:04 PM
pr_350z
Oct 1, 2015 05:03 PM
