03 350z Engine shut off while driving.
Old Sep 6, 2011 | 11:52 AM
zolaman8's Avatar
zolaman8
Default 03 350z Engine shut off while driving.
I was coming back home from school and all of sudden my car shuts off and I lost power steering. I was fortunate it happend inside my apartment but when I tried restarting the car to park it would crank but not run.
I checked all the fluids and it checked out good. I waited about 5-8 minutes then tried starting the car again, it worked with exception of check engine light on.
What could possibly be wrong with my car? Any help would be appreciated before I make my trip to the stealership.
2003 nissan 350z touring A/T. About 110,000 miles. Completely Stock.
Old Sep 6, 2011 | 12:47 PM
gotrunks2287's Avatar
gotrunks2287
where in California are you?
Old Sep 6, 2011 | 12:50 PM
djamps's Avatar
djamps
Engine grounds. -- there are two on the front timing cover join to one grounding point on the chassis (the cable is a Y cable basically). These are either loose or corroded -- have them cleaned and surfaces sanded down, then reattach firmly.
Old Sep 6, 2011 | 06:07 PM
zolaman8's Avatar
zolaman8
fullerton.
Thanks guys for the reply. I had job interview today so I was driving again hoping it doesn't happen again but it did. I drove about 7minutes then car stalled again in middle of street. I waited about 5minutes with emergency light on hoping nobody honks at me or hit me.
Once I got my car started I was very fortunate because I was maybe like .3mi away from Buena Park Nissan dealership. I took it in and explained what happend.
About two hours ago I got a call from them and said it was my crankshaft sensor that is bad and needs to be replaced. I go school and I need my car so even with stealership's high price I took their offer.
Total cost $639+tax including timing belt.....
Picking up my car tomorrow. And yes I still went to my job interview after my friend picked me up.
Old Sep 9, 2011 | 12:06 PM
dragonball d's Avatar
dragonball d
hope you get your job =]
good luck
Old Sep 9, 2011 | 12:16 PM
CRIDDA's Avatar
CRIDDA
****, you got raped. sensor is $50 and takes about 5 mins to replace. Wish I saw this earlier and could have saved you hundreds.
http://www.partsgeek.com/gbproducts/...ek+Google+Base
Also we have a timing chain and if it is not broke, it does not need to be replaced.
Old Sep 9, 2011 | 12:21 PM
ASNTech's Avatar
ASNTech
Originally Posted by zolaman8
fullerton.
You got TOOK. As mentioned, no timing belt. You might want to verify what they did. With diag, that job should not pay more than 2.0 hours which is $220 on the high end of labor rates. With a rough cost of $50 and tax, that job should have been around $300 and that's a high estimate.
Old Sep 22, 2011 | 08:48 AM
niceguy1067's Avatar
niceguy1067
You really got took.... There was actually a recall done back in 2004 for the 2003 350z crank position sensor, camshaft position sensors and it was definitely not the timing belt. What they may have fixed were all three of those sensors and the variable timing control sensor. You can go ahead and look it up on www.NHTSA.Gov<http:// www.NHTSA.Gov and see if you VIN number falls within. I too also have a 03 350z touring edition and I took it to the dealer and printed out some pages and they replaced the parts FREE.
Old Sep 22, 2011 | 08:56 AM
JaE35z's Avatar
JaE35z
oh *** no are you serious? 600 dollars I would throw a fit
Old Nov 4, 2011 | 10:48 AM
zpaba001's Avatar
zpaba001
I have the same issue. It just happened for the first time on my way to work today. Engine shut off on the freeway at 90mph in the rain. A quick turn of the key and things were back on. If this were to happen under braking or in a turn though, I would be in trouble. I checked the nhtsa website but could not locate any recall issues on the cam or crank sensors. Nice guy, can you pm me the info you printed out? I was planning on purchasing from partsgeek and doing it myself, but if it's covered id like to have the stealership do it.
Old Jul 4, 2012 | 05:27 PM
Durs22's Avatar
Durs22
Default Watch those dealers
I had 95 Altima same thing every couple of years I had to replace the camshaft sensor but on my 350 z they replaced my motor under warranty while it was out I ask them to replace the clutch they told $2000 to change it ...keep in mind the motor was out of the car n they had to take the old one off n put it on the new motor so they try to charge me $2000 to open a box after a fight a the police called on me I got them down to $150 after everything was done and I picked up the car it was free just the price of the new clutch $350 .... ANd THE COP TOLD ME THEY TRY TO RIP HIM OFF TO SO WATCH OUT ON ALL DEALERSHIPS WORKING ON YOUR CAR THEY WILL RIP U OFF!!!!!!
Old Jul 4, 2012 | 08:06 PM
taywan's Avatar
taywan
Holy hell-That sucks *****. Sorry to hear they got it in on you. They seriously told u they replaced the timing belt? I understand everybody has to make a dollar but jeeZ!! Killing people.
A mistake isn't a mistake if u learn from it.
Old Jul 5, 2012 | 01:30 AM
myfirstzcar's Avatar
myfirstzcar
Sounds like you've got more dollars than sense.
Good luck with the job though.
Old Nov 13, 2012 | 10:03 AM
ilovegirls's Avatar
ilovegirls
how long is the recall good for?
etkms
Jun 19, 2022 06:30 PM
_koubie_
Sep 20, 2015 06:34 PM
