***URGENT*** Shifter popped out of gear!
Old Sep 21, 2011 | 08:23 AM
G4nismo's Avatar
G4nismo
Default ***URGENT*** Shifter popped out of gear!
So I was driving down the road to work when all of a sudden my shifter just what seemed like popped out of gear as i was trying to shift to second.
I quickly decided to drive my car into the nearest parking lot while the car still had momentum and now my car is sitting at the traffic court parking lot.
I can't engage into any gear. The shifter moves around like i'm pushing it down to go into reverse. I can't even go into reverse.
Its the OEM shifter with just an aftermarket shift ****. Funny thing is, I have the TWM short shifter coming in tomm.
But does anyone have any idea what the issue could be? Any help would be greatly appreciated.
Old Sep 21, 2011 | 10:00 AM
tonyzS/C03's Avatar
tonyzS/C03
hmmmmm i had a similar thing happen to me in another car that I used to have but mine got locked into 5th gear vise not being able to engage any gear... only thing that I could think of would be maybe a syncro or something...
Old Sep 21, 2011 | 10:14 AM
djamps's Avatar
djamps
Sounds like you broke the linkage.
Old Sep 21, 2011 | 10:32 AM
G4nismo's Avatar
G4nismo
how involved is it to replace this?
Old Sep 21, 2011 | 11:18 AM
G4nismo's Avatar
G4nismo
i'm in a debate whether i should take this to a local reputable shop or to nissan.
Thing is, i have the extended warranty but not sure if this would be covered by nissan.
any suggestions?
Old Sep 21, 2011 | 01:19 PM
Deteria's Avatar
Deteria
Prolly put on stock shiftknob and get it fixed under warranty.
Old Sep 21, 2011 | 01:24 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
quick and easy thing to check
pop open the shifter surround, remove the 4 10mm nuts that hold the metal plate and larger rubber surround, and then remove the smaller rubber boot that surrounds the base of the lever - see if the linkage is still bolted to the shifter - it's a single nut/bolt, I want to say 12mm
if that's not it, it will require more careful inspection by a shop
Old Sep 21, 2011 | 02:44 PM
G4nismo's Avatar
G4nismo
Thanks a lot!
Old Sep 22, 2011 | 11:06 AM
G4nismo's Avatar
G4nismo
* update:
luckily it was just the shift rod bolt that came loose!
whew!
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
apex locator
Oct 6, 2015 05:58 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
