Help!! Orange light with exclamation mark
Old Sep 21, 2011 | 05:15 PM
Obey_Z's Avatar
Obey_Z
Default Help!! Orange light with exclamation mark
Every time i cruise around 5th gear, an orange light shows up on my dash! Exclamation mark with like a half a circle around it that's the orange light! Any clue what it is?!!???!!?!?!?
Old Sep 21, 2011 | 05:23 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Low tire pressure or non-working TPMS.
/thread
Old Sep 21, 2011 | 05:28 PM
Obey_Z's Avatar
Obey_Z
No its not because of the tire pressure :'(
Old Sep 21, 2011 | 05:33 PM
DavesZ#3's Avatar
DavesZ#3
Check your owners manual. We're pretty sure that's what it is
Old Sep 21, 2011 | 05:35 PM
sevensinz79's Avatar
sevensinz79
it's TPMS, i get it sometimes driving long distances but then it goes away? my friends 370z does the same thing
Old Sep 21, 2011 | 05:36 PM
DavesZ#3's Avatar
DavesZ#3
Pick the one that looks the closest....
Old Sep 21, 2011 | 05:39 PM
3hree5ive0ero
Retired Admin
^ Just as a hint, there's only 1 in the above diagram that matches your description in a Z and it's already been named above.
So, you manually checked each tire to make sure they were at the correct pressure?
FYI, you should be able to see in your little computer (left gauge of the 3 gauges above the cubby) which wheel with the bad TPMS or low tire pressure is tripping the light.
edit - you can see it on the older models, 03-06
Old Sep 21, 2011 | 05:41 PM
Obey_Z's Avatar
Obey_Z
Well from that picture its the same exact one as the low tire pressure. BUT it just goes off with out the long "beep" and doesn't blink PSI nor change on the gauge. It just turns on. Get me?
Old Sep 21, 2011 | 05:44 PM
3hree5ive0ero
Retired Admin
Pretty sure your question has been answered above multiple times already.
Old Sep 21, 2011 | 05:46 PM
DavesZ#3's Avatar
DavesZ#3
That sounds like you don't have the sensors in the car or a sensor is dead. how about some details like, year of car, aftermarket wheels or OEM? If pre-07 model, what displays in the triple-meter for the tire pressures?
Old Sep 21, 2011 | 05:47 PM
Obey_Z's Avatar
Obey_Z
But all my tires are at the correct psi. o.0
Old Sep 21, 2011 | 05:48 PM
RMichael's Avatar
RMichael
Does that TPMS light come on after you've driven say.....30 or so miles and turn off when you shut the car down then come back on when you've driven say a bit over 30 miles again?
Just guessing.
3hree5ive0ero
Retired Admin
/thread
Get me?
Old Sep 21, 2011 | 05:49 PM
Obey_Z's Avatar
Obey_Z
05 coupe 18 OEM wheels, and the tire pressure for my wheels are at 35/36
Old Sep 21, 2011 | 05:52 PM
PikesPeakZ's Avatar
PikesPeakZ
I think you're missing the point. Failing TPMS will cause your symptoms, regardless what your tire pressure says. One of them is failing. When the light comes on check which tire is reporting incorrectly.
Obey_Z's Avatar
Obey_Z
But it does work, because when one of my tire looses pressure the light goes of, along with the beep and also the light blinks.
PikesPeakZ's Avatar
PikesPeakZ
Get me?
Pretty sure you don't know what you're talking about
Old Sep 21, 2011 | 05:54 PM
RMichael's Avatar
RMichael
Anniversary?
Old Sep 21, 2011 | 05:55 PM
DavesZ#3's Avatar
DavesZ#3
You have a sensor with a weak and dying battery. The sensors only turn on when the car speed gets over 20 mph. That starts draining the battery down until the point where it stops transmitting. Once that happens, the CPU loses the signal and the warning light comes on. Initially, you may have to drive around for 30, 45, 60 minutes or more. Eventually the time before it fails will get shorter and shorter, maybe 10-15 minutes. If you park the car for a short time, you can drive it and the light won't come on again until the battery power drops.
Trust me on this one. I just changed a sensor for this very reason. They are designed with a battery life of about 7 years. Your 05 is probably on it 6th or 7th year of use.
BTW - note that nowhere in that explanation did I mention correct tire pressure. It has nothing to do with the problem.
3hree5ive0ero
Retired Admin
I quit.
Clearly.
