cost to have springs in clutch replaced?
Old Sep 27, 2011 | 01:53 PM
ksuberk54's Avatar
ksuberk54
Default cost to have springs in clutch replaced?
I know the cost of the springs is like $5-25, but what will it cost me to have someone do it at a shop and also what is the cost to have someone flush my clutch fluid and replace it with the clear fluid? thanks in advance.
Old Sep 27, 2011 | 06:10 PM
winchman's Avatar
winchman
What springs in the clutch are you talking about?
There's a diaphragm spring in the pressure plate assembly, but it's not something you'd replace. You'd just put in a new assembly. It's also called a clutch cover.
There's also some springs in the center of the clutch disc, but you'd replace the whole disc.
Either of those will involve dropping the transmission, and that's going to cost several hundred dollars at a minimum. The two are normally replaced together, so the parts will be several hundred more.
I have no clue what springs in the clutch you could get for $5-25.
Flushing the fluid and bleeding the system sounds like an hour of shop labor, so it's probably around $100, if they know what they're doing. If they don't know what they're doing, you'll get the car back with a dragging clutch or other problems that will make shifting gears a nightmare.
Old Sep 27, 2011 | 06:12 PM
ch1215g's Avatar
ch1215g
well if you are talking about the springs in the clutch it does not make sense at all to replace those. You might as well change your clutch and anything else in there that needs to be changed
Old Sep 27, 2011 | 06:13 PM
ksuberk54's Avatar
ksuberk54
well my clutch just feels kind of choppy sometimes. I think it needs new fluid and possibly have the pedal lubricated but it just feels like it's not springy enough. I
Old Sep 27, 2011 | 06:14 PM
ch1215g's Avatar
ch1215g
i think your leaning towards a new clutch
Old Sep 27, 2011 | 10:19 PM
ksuberk54's Avatar
ksuberk54
if by new clutch you mean new clutch assembly yes but if by new clutch you mean the actual clutch then no. It has no problem getting into gear or anything.
Old Sep 28, 2011 | 02:34 AM
winchman's Avatar
winchman
Then it's probably the master and slave cylinders and pedal lubrication you need to think about.
You can lube the clutch pedal bushings and the clevis rod under the dash.
Then remove most of the old fluid from the reservoir with a turkey baster, put in new fluid, bleed the system till you get fresh fluid, and refill the reservoir.
If that doesn't improve the situation, rebuild the master and slave cylinders.
Old Oct 1, 2011 | 04:55 PM
Tougelabs's Avatar
Tougelabs
Default Choppy ?
Describe the pedal a bit more, does it fluctuate or is it a constant ??
The pedal should have a 1/4" play up top and then a smoother transition all the way to the bottom. If this isn't what you have then it's most likely a hydraulic related issue i.e master and slave. In all honesty i would check the system if everything checks out it may be a TOB on its way out or possibly your pressure plate.
Good luck
07ZEKE
Aug 23, 2021 09:15 PM
ablaine
Nov 29, 2016 10:13 AM
