tire pressure light!
Old Oct 24, 2011 | 04:06 PM
ap2_S2Kyle's Avatar
ap2_S2Kyle
Default tire pressure light!
Hey guys i have a base but the tire pressure light (!) came on the other day..its came on once before for about a minute then went away, but now its been on for a couple days..I have a base model so i dont understand..Car is an 07 if that makes any difference..Should I just try resetting the ecu? thanks
-kyle
Old Oct 24, 2011 | 04:14 PM
Waiz's Avatar
Waiz
Did you actually check the tire pressure manually and verify that it's within factory spec?
Old Oct 24, 2011 | 04:42 PM
DavesZ#3's Avatar
DavesZ#3
It's fall. Cooler temperatures mean lower tire pressures. Pressure drops below 28psi and off the alarms go.
Once you drive the car, the tire heats up, pressure rises and warning goes away. That being said, if your pressure is down that low, it's probably too low normally. 35psi is the norm.
Old Oct 25, 2011 | 12:06 AM
ap2_S2Kyle's Avatar
ap2_S2Kyle
^i get that but i have a base model..i thought i dont have tpms
Old Oct 25, 2011 | 02:45 AM
ChuckW's Avatar
ChuckW
It's been a federal law that all cars sold in the US have them since September 1, 2007.
http://www.tireindustry.org/pdf/TPMS_FinalRule_v3.pdf
You can thank Ford/Firestone for this one.
Old Oct 25, 2011 | 11:44 AM
ap2_S2Kyle's Avatar
ap2_S2Kyle
thanks i feel like a noob did a search and 07 and up base did come with the tpms
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
