Motor Swap Issues -
Old Oct 28, 2011 | 05:58 PM
Moncef's Avatar
Moncef
Default Motor Swap Issues -
I'm not sure if I'm posting in the right section. If not, please move accordingly - thanks.
We put a fresh DE in my buddy's '03 350Z. It cranks, but did not fire. All the sensors are hooked up from what we can see, and there are two SES codes: P1564 and P0462. From my research, these two codes don't have anything to do with the car cranking.
Is there anything specifically that we should be looking for? The grounds appear to be all hooked up.
Any suggestions or tips on this?
Thanks
Moncef F
Old Oct 29, 2011 | 02:46 AM
Spork's Avatar
Spork
Air, fuel, spark.
Have you completely looked over all of these? Does the fuel pump run if you turn the key to ON without starting?
Old Oct 29, 2011 | 08:32 AM
shakuya88's Avatar
shakuya88
Originally Posted by Spork
Air, fuel, spark.
+1
Step 1, can you breathe? Air is taken care of
Step 2, Pull a plug reconnect to coil and crank, does it zap you (jk) touch it to ground and does it spark?
Step 3 Since fuel is the hard one to see without pulling part most of the motor, Doing the other 2 first you've now narrowed it down to fuel most likely
Hope that helps. Also, Take intake off, put car in 1st or drive, and step on gas and see if throttle blade moves
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
