Help installing serpentine belt on 07 350z HR
Old Nov 3, 2011 | 07:44 PM
BLACKNISMO's Avatar
BLACKNISMO
Default Help installing serpentine belt on 07 350z HR
I read the diy guide for the hr belt and apparenlty I need a breaker bar so I went to sears to buy one I bought a (15 inch flex T-handle 1/2 in drive) I tryed fitting it to where I'm suppose to on the auto tensioner but it seems not to fit the fans from the radiator seem to interfere? Any help would be appreciated thanks . Side note I already removed the overflow tank
Old Nov 4, 2011 | 05:10 AM
winchman's Avatar
winchman
I just looked at my '08, and I'm pretty sure there's enough room for the wrench as shown in the picture in the DIY.
Has your car even been involved in an accident or had work done that might have moved things around?
Old Nov 4, 2011 | 07:23 AM
flecko28's Avatar
flecko28
I remember i had a near impossible time getting a breaker bar in there...i wound up using a tool similar to this:
http://www.amazon.com/Lisle-59800-Se...sim_sbs_auto_1
Old Nov 4, 2011 | 09:08 AM
BLACKNISMO's Avatar
BLACKNISMO
The car has been involved in an accident from the front left . I went at it this morning again I decided to take off the radiator fans but no luck, in doing so I removed the radiator hose and made a mess I hope my electrical connections for the radiator fans aren't messed up now! Should I just let'em dry and everything will be ok?
Old Nov 4, 2011 | 01:40 PM
ChuckW's Avatar
ChuckW
Originally Posted by BLACKNISMO
...so I removed the radiator hose and made a mess I hope my electrical connections for the radiator fans aren't messed up now! Should I just let'em dry and everything will be ok?
Those connections see rain/moisture all the time. You could just rinse their exterior with some clean water and never have an issue.
If you're really paranoid open the connection, let them dry or blot them dry with paper towels, give them a shot of WD40 where the terminals make contact, blot off the excess and reconnect. Don't let any of the WD40 solvent stay on any rubber!
Old Nov 4, 2011 | 09:28 PM
BLACKNISMO's Avatar
BLACKNISMO
Thanks for all the help chuckw & flecko 28
Old Nov 5, 2011 | 05:12 AM
dcains's Avatar
dcains
I just removed those big plastic nuts (for lack of a better word) holding the top of the radiator in place, which allows the radiator to shift forward enough to fit the breaker bar into the tensioner. I have a basic Craftsman 1/2" breaker bar, which really doesn't have a very thin profile.
Vigman
Nov 17, 2015 04:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
