350z starting
Old Nov 10, 2011 | 04:39 AM
mwatts3's Avatar
mwatts3
Default 350z starting
I just purchased a 2003 350z with 93,000 miles.The previous owner told me that on a couple of occasions it would turn over but would not start. It happened to me for the first time yesterday.I started it cold and drove it 2 miles to gas station and filled it up.When I tried to start it it spun over very good but would not start.I sat there a few seconds and tried again with same results.I waited a few seconds more,put key back into ignition turn on but I paused before I tried the starter,and then it started up.I am a fair mechanic and do all my own work,but these kind of intermit.problems are the worst to find.I would appreciate any help or suggestions I could get.
Old Nov 10, 2011 | 05:07 AM
F34RL355's Avatar
F34RL355
i beleive u flooded the engine, when its cold it runs rich and if ur turn it off right away, it wont wanna start cause its flooded
Old Nov 10, 2011 | 06:37 AM
silvertouringz's Avatar
silvertouringz
i say its the key. r u throwing the NATS code?
Old Nov 10, 2011 | 06:44 AM
PerfZ's Avatar
PerfZ
+1 happens to a buddy with an '03 Track and dealer says it is probably that. Pretty sure that pulling the key and starting over resets the NATS. Expensive repair from what I have heard. Assume you are not throwing a SES light?
Old Nov 10, 2011 | 07:21 AM
gvulakh's Avatar
gvulakh
I lost my key and fob to my car(07 350Z). I got my spare key programmed(bought it a long time ago and just had it cut).
The next morning the car would not start. It fired up after a couple attempts.
After some reading I started to turn the key to the on position and let it beep 3 times before firing the engine, no starting issues since...........
Old Nov 10, 2011 | 08:30 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Nov 10, 2011 | 08:48 AM
BonesZ33's Avatar
BonesZ33
I agree, most likely the transponder chip not being read. I've had it happen a couple times before.. Sometimes the chip gets dirt and crap in it from being in your pocket, so clean it out and try again.
Old Nov 15, 2011 | 04:59 PM
mwatts3's Avatar
mwatts3
Default Starting Problem
Thanks for all the suggestions gentlemen.I think it is the key as some said.My son had a camero that done a similar thing.
Old Feb 12, 2012 | 04:34 PM
SLOPOS's Avatar
SLOPOS
Wait, you have spawn....poor poor world...
Old Feb 13, 2012 | 08:46 AM
TreeFiddyGee's Avatar
TreeFiddyGee
lolwatbro
Oct 9, 2021 04:58 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
Darkspy
Sep 7, 2015 09:09 PM
