Need Help w Jacking Points
Old Nov 10, 2011 | 11:45 AM
Csig's Avatar
Csig
Default Need Help w Jacking Points
Hey guys ima new Z owner and i just bought some Berk test pipes. Can anyone give me an instructional on how to get the car on 4 stands? I can fit the jack under the car but i cant get it up so im obviously doing something wrong. Can anyone tell me the points or just flat out telll me how to get it up high enough to put it on the stands? Thanks guys
Old Nov 10, 2011 | 02:03 PM
Just a suggestion. Put a subject in the subject line like
Squeaking brakes
instead of
Help
Need help immediately
If you don't help right away I will die!
Old Nov 10, 2011 | 02:40 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
and use that same strategy for the search function. Type in help and see what you get back.......a slew of junk threads just like this.
IF you cannot figure out how to get the car up on jacks, you should not be working on, in or under it.
Leave it to the pros.
Old Nov 10, 2011 | 02:52 PM
Waiz's Avatar
Waiz
This is not a DIY
Squeaking brakes
instead of
Help
+1
OP refer to this thread for your answer:
https://my350z.com/forum/8293361-post1.html
Old Nov 10, 2011 | 03:46 PM
122554's Avatar
122554
Read your owner's manual
Old Nov 10, 2011 | 07:40 PM
teamevolution2's Avatar
teamevolution2
use the pinch welds running under the car where your factory jack goes its the strongest part of the car.
ablaine
Nov 29, 2016 10:13 AM
Alexreyes
Sep 30, 2015 11:30 PM
Tochigi_236
Sep 27, 2015 03:40 PM
