Snapped Drive Shaft
Old Nov 27, 2011 | 08:14 AM
TimsZee's Avatar
TimsZee
Question Snapped Drive Shaft
So I snapped my drive shaft at the track. First run down the track ran fine, second time snapped off the line. Anyways I ordered a new one, whats the best way about putting the new one back in.
Attached Thumbnails Snapped Drive Shaft-1322413561722.jpg   Snapped Drive Shaft-1322413591303.jpg   Snapped Drive Shaft-1322413545978.jpg
Old Nov 27, 2011 | 08:29 AM
faiz23's Avatar
faiz23
FEZZZZZZ
How did it break and did you do a high rpm launch or whats up. Not sure on tips on how to put it back in..i guess how you took it out. Use a FSM that is available all over the web to help you out. Did you order OEM or aftermarket drive shaft and how do you go about making sure it does not happen again.
Old Nov 27, 2011 | 08:36 AM
str8dum1's Avatar
str8dum1
it just bolts in. no tricks
Old Nov 27, 2011 | 09:00 AM
TimsZee's Avatar
TimsZee
Yea I launched about 3300-3500. As far as putting it back in the same way I took it out is impossible due to that fact that its in 2 pieces now. The only reason why I'm asking how to put it back in there are metal or plastic caps that are over the bolts just not sure how about getting them off.
Old Nov 27, 2011 | 09:03 AM
TimsZee's Avatar
TimsZee
As you can see the cap its self is in there pretty good that's that where I'm getting at.
Old Nov 27, 2011 | 11:10 AM
08NismoZ's Avatar
08NismoZ
How much power are you putting down? I've launched at 5k rpm's and never had any problems. That's crazy
Old Nov 27, 2011 | 11:17 AM
TimsZee's Avatar
TimsZee
280 with a few bolt-ons. Just one of those days I suppose. Another question would be when I do get the new shaft, am I going to use my old piece that goes into the tranny and rear diff. Just put them in there and bolt on the new shaft?
Old Nov 27, 2011 | 11:19 AM
350zion's Avatar
350zion
Professional
4 bolts at the rear yolk flange...
Old Nov 27, 2011 | 11:20 AM
350zion's Avatar
350zion
Professional
O n v-tach kicked in Yo!
Old Nov 27, 2011 | 11:36 AM
Italianjoe1's Avatar
Italianjoe1
You're looking at the universal joint, that isn't what you have to remove. Just unbolt from the rear flange on the differential, and slide it out of the trans. Installation is reverse of removal.
Old Nov 27, 2011 | 11:44 AM
TimsZee's Avatar
TimsZee
Yea, v-tach kicked in real hard. Thanks for all the help!
Old Nov 27, 2011 | 12:38 PM
bbs350z's Avatar
bbs350z
I got an extra oem driveshaft ill sell for cheap! As far as install, you wanna slide the yolk in first then bolt it up to the diff. 17mm wrench and socket! I'd check to see if other drivetrain piecesare fugged, because our driveshaft is insanely strong
Old Nov 27, 2011 | 01:18 PM
TimsZee's Avatar
TimsZee
Already got one in on its way here for a pretty good price. Thanks for the thought!
Old Nov 27, 2011 | 01:31 PM
kyle22's Avatar
kyle22
How did you break the drive shaft with just minor bolt on's and launching at 3.5k? Crazy man sorry to hear that; but the install is easy. Slide the Yolk right in then tighten the 4 bolts on the rear to spec.
You buy an aftermarket one or an OEM one?
what year is the car and how many miles are on it?
Old Nov 27, 2011 | 01:59 PM
2bad240's Avatar
2bad240
You from nc? Are you the guy that broke a couple months ago?
Old Nov 27, 2011 | 02:50 PM
TimsZee's Avatar
TimsZee
03 touring with 58k, and yea man thats me.
Old Nov 27, 2011 | 02:52 PM
TimsZee's Avatar
TimsZee
And yea I bought a OEM for 110$ with year warrenty. Cant pass that up.
Old Nov 27, 2011 | 02:57 PM
TimsZee's Avatar
TimsZee
The only thing I can thing of that might have played a roll in it would be the burnout. I had some minor wheel hopping, maybe one hop to much..?
Old Nov 27, 2011 | 05:09 PM
bbs350z's Avatar
bbs350z
I recommend solid diff and subframe mounts
Old Nov 27, 2011 | 06:05 PM
TimsZee's Avatar
TimsZee
Those look like they are gunna be a PITA to install..
