Heater not working well after swapping the motor
Old Nov 29, 2011 | 05:09 AM
ericjackson's Avatar
ericjackson
Default Heater not working well after swapping the motor
i just finished swapping out my engine and the heater isnt working well. i feel a little heat while driving, but idle, i feel none. At first i thought, "ive seen this before on my last engine change, coolant is low." so I looked and sure enough, it was a little low because it had circulated through the engine some from driving/running. I topped it off and the problem persisted, but i only drove it a short distance. I checked again this morning and its still full (radiator).
Am i missing something else?
My new mods during the engine swap were a new mishimoto radiator and mishimoto thermostat. The car seems runs much cooler temps judging from the thermostat gauge, but i wouldnt think that would make the heater not work.
Old Nov 29, 2011 | 05:17 AM
RandomHer0's Avatar
RandomHer0
Air.
Old Nov 29, 2011 | 05:19 AM
ericjackson
air in the system? alright, how do i get it out? let it run with that top vent open in the hose that i *think* goes into the heater by the battery?
Old Nov 29, 2011 | 05:54 AM
RandomHer0's Avatar
RandomHer0
Scroll down to "bleeding the system"
http://crackaddict.com/~flynn/howtos...amco.howto.htm
and using a Lisle funnel makes the job a million times easier.
http://www.amazon.com/Lisle-24610-Sp.../dp/B001A4EAV0
Old Nov 29, 2011 | 07:46 AM
qmoney06's Avatar
qmoney06
Thanks for sharing these two links.
Old Nov 29, 2011 | 07:49 AM
ericjackson
yeah thanks. ill try that. maybe my drive to work today got some of the air out
Old Dec 1, 2011 | 06:18 AM
RandomHer0's Avatar
RandomHer0
You can also used the bleeder valve at the back, not nearly as effective.
