Burnt Clutch?
Old Jan 8, 2012 | 01:29 PM
Raybrant's Avatar
Raybrant
Default Burnt Clutch?
So I'm starting to get reasons to believe my oem clutch is starting to wear out. The problem I'm experiencing is a loss of power in the higher gears (3rd to 6th).
I can be cruising on the highway at around 50mph and when I try to "punch it" and give it more gas like when I'm trying to merge into a lane, my rpms would jump like they would normally but then die down a second later as if power wasn't transmitting. I suspect either a worn out clutch (at 86k miles, I don't doubt it) or fuel/air problems.
I have minimal mods done: Injen CAI, HKS exhaust and Berk HFCs.
Below is a vid of it happening. I think I was cruising in 4th. I'm holding the throttle constant before giving it more gas.
http://youtu.be/FaC2BWNLJjg
Edit: Also my CEL did come on before and the code checked out to be a running lean code. I drove it some more and resetted the ECU a couple times thinking AFR would remap and the CEL went away for good.
Old Jan 8, 2012 | 02:07 PM
carsfreak88's Avatar
carsfreak88
its time for a new clutch
Old Jan 8, 2012 | 02:50 PM
The clutch is slipping. It is not holding the flywheel. Crankshaft and flywheel goes round-and-round - drive wheels do not.
Old Jan 8, 2012 | 03:39 PM
Raybrant's Avatar
Raybrant
Okey doke, that's all the confirmation I need.
Figured it was the clutch (previous owner was a woman) but wanted a 3rd opinion. Thanks!
Old Jan 9, 2012 | 10:41 AM
BoomerZ33's Avatar
BoomerZ33
at that mileage i would definitely want to have my clutch changed if not done so already. the woman was probably learning stick.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
