Fail bolt?
Old Jan 20, 2012 | 02:09 PM
N80's Avatar
N80
Default Fail bolt?
I was looking at the sticky threads in this forum and noticed one about the 'fail bolt' on the front wheel brake disk. The post says it is there to keep people from putting rear staggered wheels on the front.
That may be, but this bolt, which the G35 service manual calls "the special bolt" has a much more ingenious purpose.
Removing brake rotors can sometimes be very difficult. Hammers are often required. With this little bolt you just remove it, then remove the metal collar and then drive it back in. It bears on the wheel hub and pops the rotor right off.
So if you are inclined at all towards DIY brake work, do not discard this little bolt. It can save you a ton of time.
Old Jan 20, 2012 | 08:15 PM
DavesZ#3's Avatar
DavesZ#3
Front rotors never seem to be a problem, it's the rears that seem to get stuck for most.
Old Jan 20, 2012 | 08:51 PM
johnwigs's Avatar
johnwigs
seriously? mind is blown right now...
Old Jan 20, 2012 | 09:23 PM
R350Zz33's Avatar
R350Zz33
why would i use a bolt when i have a "BFH" a screw will take much longer and require more energy.
Old Jan 21, 2012 | 03:37 AM
N80's Avatar
N80
I'm just sayin......
Old Jan 21, 2012 | 03:45 AM
sry110's Avatar
sry110
I agree with you. Using a jacking screw to press the rotor off the hub is the correct method. Hitting the rotor with a BFH is the quick method.
Old Jan 21, 2012 | 05:58 AM
Italianjoe1's Avatar
Italianjoe1
Lots of cars have threaded holes on the rotor to help remove it, even if there isn't a bolt in them in the first place.
Old Jan 21, 2012 | 05:17 PM
N80's Avatar
N80
It would definitely take me longer to find the right size bolt than the right sized hammer.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
