Engine Check Light On
Old Mar 13, 2012 | 03:51 PM
spjza80tt's Avatar
spjza80tt
Default Engine Check Light On
Good Day all.. was driving a week or so ago& Engine Check light came on, the face is out of factory warranty, 2006 Manual checked the codes & got -
P0340 camshaft position sensor a circuit/ bank 1
P1078 exhaust valve timing circuit bank 1
P0014 Exhaust B camshaft position timing - over advanced bank 1
has anyone dealt with these problems before?
The car will sometimes turn off while driving, the idle jumps up and down from 500-1600 Rpm.
Old Mar 13, 2012 | 04:34 PM
Neimad's Avatar
Neimad
If you're lucky its just the Bank 1 Exhaust Cam Sensor. Mileage?
Old Mar 13, 2012 | 04:58 PM
Spork's Avatar
Spork
Rough diagnosis off the top of my head... like the person above me... Cam Position Sensor is failing. Should be a cheap fix if you can find a Z in a junkyard.
Old Mar 13, 2012 | 05:07 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
As stated above - change the cam sensor first. Then clear codes and see if the others come back.
The cam sensor is a common replacement item.
Old Mar 14, 2012 | 04:49 PM
spjza80tt's Avatar
spjza80tt
I hope, I'm going to order the part tonight, Bank 1 is passenger/battery side correct? 90,523 miles
Old Mar 14, 2012 | 04:59 PM
Neimad's Avatar
Neimad
Correct, pass side. The sensors are the same part but one has an angled connector.
http://www.courtesyparts.com/350z-pa...5_743_745.html
Good luck!
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
