FRONT WHEELS Noise Problem
Old Mar 19, 2012 | 07:46 AM
DrGOLD's Avatar
DrGOLD
Default FRONT WHEELS Noise Problem
i have a 2003 touring.
I changed my rims 2 weeks ago but recently started to hear a noise coming from the front two wheels. its a swishing sound that comes with each tire rotation. I'm not sure if its the brakes or what.
any help would be appreciated.
Thanks in advance
Old Mar 19, 2012 | 08:16 AM
sry110's Avatar
sry110
Does it sound like metal-on-metal? Like a light scrape? Could be your brakes but it's odd that would pop up due to changing your wheels.
Are the wheels or brakes aftermarket? And if so, is there ample clearance between the brake caliper and the wheel balance weights stuck to the inner barrel of the wheel?
Old Mar 19, 2012 | 08:18 AM
cgkp0925's Avatar
cgkp0925
Was the sound all of a sudden, or did it progressively get worse over time?
It might be the bearings possibly, but bring it to your local shop and see what they have to say.
Old Mar 19, 2012 | 09:08 AM
DrGOLD's Avatar
DrGOLD
the wheels are aftermarket but im still on the first set of OEM brakes. it doesnt really sound like a scraping sound or metal-on-metal. im deffinitely going to check the wheel balance weights now.
Thanks
Old Mar 19, 2012 | 09:12 AM
DrGOLD's Avatar
DrGOLD
i just realized the noise so im not sure if it is getting worse. based on my research it doesnt seem like its the bearings. i will probably go to a shop soon but i just want to know what sort of direction to point the mechanics to (not too many good car shops here in FLint, MI)
Old Mar 19, 2012 | 09:20 AM
sry110's Avatar
sry110
Off-topic, but that seems rather ironic, doesn't it?
Old Mar 19, 2012 | 09:21 AM
JCat's Avatar
JCat
Does the noise vary with speed ?
Does the noise change when you apply the brakes?
Does it happen on both acceleration and deceleration?
Old Mar 19, 2012 | 09:25 AM
DrGOLD's Avatar
DrGOLD
i think the noise becomes more frequent as i speed but i cant tell too much because the car gets to windy and noisy. the brakes are starting to get worn out and squeek under pressure but i dont think the noise changes. and it happens in both.
Old Mar 19, 2012 | 09:54 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Did you remove the little bolt that prevents you from putting the stock rear wheels on the front?
Old Mar 19, 2012 | 10:06 AM
DrGOLD's Avatar
DrGOLD
yes
Old Mar 19, 2012 | 10:34 AM
JERZ350's Avatar
JERZ350
Possibly the shop hit the dust shield when putting the wheels on, enough where it barely makes contact?
Old Mar 19, 2012 | 01:29 PM
DrGOLD's Avatar
DrGOLD
thanks, i looked but it doesn't look like it
DrGOLD's Avatar
DrGOLD
could it possibly be that with the wider rims messed up the cars alignment and its just my tires making the noise?
Old Mar 19, 2012 | 01:33 PM
DrGOLD's Avatar
DrGOLD
not really ironic. horrible economy and low income leads to a lack of nicer cars on the roads and thus limiting the amount of business a good car shop could get. i would have to go to detroit to get any really big install done
Old Mar 19, 2012 | 02:07 PM
terrasmak's Avatar
Very possible, very possible your alignment was bad before.
Old Mar 19, 2012 | 07:43 PM
DrGOLD's Avatar
DrGOLD
thanks everybody for the quick replies. I ordered some hawk hps brakes and will get everything checked out when i put on the brakes. also will probably do an alignment some time soon.
Thanks for the input
Old Mar 20, 2012 | 08:54 AM
ehsan's Avatar
ehsan
hmm... i ****ed one of my rims up and got a new one.. put it on and got noise like you are saying as well.. when i rode on the donut no noise but when i put this brand new rim on thats when i noticed the noise ..
It was pitch black at night and no lights and i hit a curb going like 40+... dented the rim but seems like i might of done more damage than that...im thinking bearing or other suspension parts. maybe alignment
Old Mar 20, 2012 | 09:14 AM
DrGOLD's Avatar
DrGOLD
i haven't hit any curbs or such but i'll still check for any other damage. Just let me know what you find please. I also will update everyone with what i find.
Thanks
Old Mar 20, 2012 | 09:34 AM
ehsan's Avatar
ehsan
ya you just switched rims..so..balanced, aligned, and bearings.
also if if you rims were new or used...check for bends?
Old Mar 24, 2012 | 10:21 AM
ehsan's Avatar
ehsan
any updates?
