Which synthetic oil for engine
Old Mar 20, 2012 | 08:41 PM
mazymus's Avatar
mazymus
Default Which synthetic oil for engine
Hi all,
I was curious to see what you guys like in terms of engine oil. I've read a few threads, and even the amazing engine oil thread (can't find the link) but am still left not knowing which one.
I'm down to motul vs mobile 1, but I've also heard not so great things about mobile 1..
So, between the two (or if there is another clear better one, by all means do share) which one?
Also for a northern cali climate, what grade? I'm thinking 10W30 should be enough given the temps, but perhaps 5W30 to be on the safe side?
This is for a daily driver 2003 Z.
Thanks
Old Mar 20, 2012 | 08:43 PM
JedixSole's Avatar
JedixSole
royal purple or mobil 1.
Old Mar 20, 2012 | 08:52 PM
terrasmak's Avatar
Amsoil is one of the best for the VQ, RP is the worst. There are a lot if good ones inbetween. I use Amsoil 5w40 euro the run Mobil 1 euro if in a pinch.
Old Mar 20, 2012 | 09:16 PM
mazymus's Avatar
mazymus
Thanks man, I did come across Amsoil, forgot to mention. I'll look into it for sure.
Why the 40? Is that more for racing, or is that also your DD? just want to make sure I"m not getting one that too viscous.
Also, I have the V3 Vortech supercharge on the car, but I don't race with it and temps are always in the 180-190 range.
Thanks again
Old Mar 20, 2012 | 09:26 PM
Dallasmavs92's Avatar
Dallasmavs92
And where's your proof of RP being the worst? I've been running RP for the past 10k miles, ( no idea what was before ) and it's been nothing but great.
Old Mar 20, 2012 | 09:35 PM
J 0 K 3 R's Avatar
J 0 K 3 R
im pretty sure synthetic oil is bad for high compression motors. synthetic has a lower viscocity which means its thinner (not good) and is probably why people are having oil burning issues. the z is high compression at 11:1 and the owners manual says specifically not to use synthetic oil. i would only use synthetic on 9:1 and under personally. ive seen 12:1 corvettes and high compression bikes blow motors due to synthetic. just cause its more expensive doesnt make it better. i get regular oil by a reputable company like penzoil, castrol, or mobil 1 and i dont burn oil or have any problems.
just in case you (or anyone) were thinking about taking your car to wallmart or equivilant, change the oil yourself every 3k miles. its not hard people, and costs around 40$.
Old Mar 20, 2012 | 10:23 PM
ImWeeZzel's Avatar
ImWeeZzel
ams oil or mobil 1, that's all I use.
Old Mar 20, 2012 | 10:39 PM
jv350z's Avatar
jv350z
M1 0w-40 or the German Castrol Syntec
Old Mar 20, 2012 | 11:07 PM
Did you just start another Best motor oil thread? Shame on you.
Old Mar 20, 2012 | 11:49 PM
hyuk28719's Avatar
hyuk28719
Using Royal Purple for little bit over a year and seeing no problem.
Old Mar 21, 2012 | 02:40 AM
terrasmak's Avatar
https://my350z.com/forum/engine-and-...-and-info.html you can also start reading, i didn't even have to search for this. It is stickied.
High compression and not being able to run synthetic . Are you ******* kidding me
Old Mar 21, 2012 | 05:18 AM
VQ35deMax's Avatar
VQ35deMax
I have been using Mobil 1 0w-40
Old Mar 21, 2012 | 05:32 AM
JERZ350's Avatar
JERZ350
I dont know about your areas, but a Costco near me has Mobile1 synthetic for cheap. about $35 for a 6qt case. ~$6 a quart while auto stores are like 8 or 9 bucks a quart. Costco likes to do a lot of $10 off of cases as well, i bought 2 cases at $25 each. Keep an eye out
Old Mar 21, 2012 | 05:46 AM
ocdz's Avatar
ocdz
Seriously, never give advice on this again. Ever.
Old Mar 21, 2012 | 06:08 AM
2008_hrthree50z's Avatar
2008_hrthree50z
Im using mobil 1 synth 5w30 and its perfect. Been running great for 7k miles. Its "rated at 15k" but ill change it at 8k
Old Mar 21, 2012 | 08:14 AM
bmccann101's Avatar
bmccann101
royal purple is a race oil that contains little to zero detergents.. your engine will carbonize fast as sh3t and youll pay more for oil..
ah the bliss of ignorance.. " it seems fine to me?"
this thread will be so full of pure opinion its going to get redonk fast haha. wait..
I just read above a few posts.. it already did get redonk.
Old Mar 21, 2012 | 08:39 AM
djamps's Avatar
djamps
So much fail in this thread it's maddening. Could a mod lock or preferably delete it?
Old Mar 21, 2012 | 08:53 AM
DaveJackson's Avatar
DaveJackson
Master
I use Mazola. It's the best.
Corn oil + E85 is a combo that can't be beat.
Old Mar 22, 2012 | 10:24 AM
mazymus's Avatar
mazymus
Well, thanks guys for your opinions and advice.
I mainly wanted to see if there was anything bad per se by going the Mobile or Motul route.
For example, I have used the MOTUL 8100 5W-40 X-cess Synthetic Engine Oil the last time around, but read that Motul can be a more viscous vs Mobile one, and therefore on colder temps not as good.
Anyways, didn't mean to start a crap tread, but was honestly curious and looking to get some advice
Old Mar 22, 2012 | 10:44 AM
tquill's Avatar
tquill
That oil analysis thread that posted earlier would be the best start. If you're ever inclined to do so, you could always get your oil tested for comparison. It costs about 25 bucks if I remember correctly.
