The Definitive Guide to Fixing the Rear Rattle / Clunk Noise
It-s the O ring from some injectors, I don't know how durable they are to the mechanical load in that area...
But I will make for sure some more resistant spacers. I think the most appropriate material is high density polyurethane. Even though from copper would be easier to manufacture, I worry about making that point very rigid. I think I should allow some elasticity for dilatation and stuff.
Why they made that hole bigger in the first place, there should be a reason for sure. That's why I am reluctant to fill it with metal spacer.
Not sure where the "space above the shock" would be.
No problem. See the attached photo. I mean the space inside this hole. I would stuff some sound deadening material in there.
I have had a very annoying and rather loud noise coming from the passenger side of the rear strut bar shortly after reinstalling a set of 08 OEM struts and springs. The noise almost sound like the rear of the car is loose and will come apart!
The sound is very similar to what others have recorded:
VIDEO1 by forged93
VIDEO2 by Carlili4190
As you can hear, the rattling noise can be fairly high pitched and seems to be coming from the interior but after removing all the interior plastic trim pieces and using dynomat/sound proofing foam, I realized that the noise only sounds like it is coming from the interior but really is coming from the suspension.
I have been following closely on the forum especially this epic thread LINK
Like others in that thread, I have tried various fixes without success. I have just learned to accept and live with it (mostly by turning up the stereo). But today I made a last ditch comprehensive effort to correct the problem and it worked! I think my ears can't believe how quiet the rear is now! I tried various fixes to no avail. I think the solution has been so elusive because:
1) Due to the design of the 350Z, especially how the top of rear struts enter into the cabin, even small suspension noises can resonate and be amplified. Also, there really is not a lot of sound proofing in the rear. The Z is therefore very prone to noise issues coming from the rear.
2) As many people on the forum have described, the problem can be temperature sensitive (e.g worse during cold temperature)
3) There can be more than one source for noise in addition to the suspension. In the past I have tried to correct one potential problem only to find that the fix did not work because there are still other sources of noise that I failed to do at the same time.
VIDEO1 by forged93
Does anyone know the actual size/dimension of the washer we would need to buy or actual technical name of the spacer to fill the space in the fork and bolt?
The bolt is 9.7 mm in diameter and the hole is 15.5 mm. Get used to the metric system, I'm an European
There is no name for the spacer as it is not specifically produced by someone for this use. Use your imagination and waht you have at hand. Reinforced rubber tube, polyurethane etc. I used some injector's o-rings form the Nissan shop.
)There is no name for the spacer as it is not specifically produced by someone for this use. Use your imagination and waht you have at hand. Reinforced rubber tube, polyurethane etc. I used some injector's o-rings form the Nissan shop.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
