New Owner of 03 350z, and problems..
Old Apr 5, 2012 | 08:11 PM
Jacob Kalina's Avatar
Jacob Kalina
Default New Owner of 03 350z, and problems..
I just recently bought an 03 nissan 350z with 104k miles, The check engine light is on and I hooked up an obd reader and it gave me a random misfire reading. I changed the spark plugs and checked the ignition coils and the car was still misfiring. It misfires at 4,000 rpm and higher so bad that Its almost like I am losing speed. Even worse in 4th and 5th gear. I changed the camshaft sensors because that was a code that came up as well. I changed both. I took the car to a shop and they said that It was my oil that was causing the misfire. They said that the oil was dirty and was "clogging" or blocking up the camshaft sensors due to the viscosity. So I changed the oil and its still misfiring.. My main questing aside from what's wrong is can a clogged crankshaft sensor cause power loss and missfire?
Attached Thumbnails New Owner of 03 350z, and problems..-car.jpg   New Owner of 03 350z, and problems..-car2.jpg
Old Apr 5, 2012 | 08:14 PM
Kingeddie's Avatar
Kingeddie
ibtl let the fun begin.!!!
Old Apr 5, 2012 | 09:30 PM
ThomasLicious's Avatar
ThomasLicious
I'm sorry for the problems but...the paint job..were you forced into buying this?
Old Apr 5, 2012 | 10:00 PM
terrasmak's Avatar
I hope he got one hell of a deal on it
Old Apr 6, 2012 | 04:52 AM
djamps's Avatar
djamps
I think the paint is your problem.
BoomerZ33's Avatar
BoomerZ33
damn that sucks. good luck with repairs.
Old Apr 6, 2012 | 05:13 AM
cgkp0925's Avatar
cgkp0925
Old Apr 6, 2012 | 05:50 AM
SirSpeedyZ's Avatar
SirSpeedyZ
your car is refusing to work because of the paint job
Old Apr 6, 2012 | 06:25 AM
Bret86944's Avatar
Bret86944
If you've got engine sludge I doubt one oil change is going to work... Sounds like the moron who owned it before you never changed the oil
Old Apr 6, 2012 | 08:35 AM
mr2blackna's Avatar
mr2blackna
more pics of the girl?
Old Apr 6, 2012 | 01:13 PM
ImWeeZzel's Avatar
ImWeeZzel
the tard that owned the car before you should be slapped...
Old Apr 6, 2012 | 01:27 PM
juicenigk's Avatar
juicenigk
Old Apr 6, 2012 | 01:31 PM
Was the car in an accident?
Is the repair finished?
Old Apr 6, 2012 | 01:54 PM
cubs4worldseris's Avatar
cubs4worldseris
try adding seafoam to the engine oil. run the car for 100 miles. change the oil.
also, run seafoam through the brake booster vacuum line and put some in the gas tank.
Old Apr 6, 2012 | 03:04 PM
zaimer's Avatar
zaimer
My thoughts exactly!
Old Apr 6, 2012 | 04:39 PM
Jacob Kalina
I tried the seafoam and still nothing. Should I try cleaning out the Camshaft sensors? Or is that a waste of time...
Old Apr 6, 2012 | 05:29 PM
bulforce's Avatar
bulforce
code?????DTC 0300 MULTIPLE MISSFIRE .0301 0302 ....... DID YOU RETRIVE THE CODES FROM THE CAR?
Old Apr 6, 2012 | 06:35 PM
Jacob Kalina
The misfire code was 0300. Random Misfire Detected.
Old Apr 6, 2012 | 06:41 PM
white boy's Avatar
white boy
Did u test drive the car before u bought it? U had to get a great deal
Old Apr 6, 2012 | 06:44 PM
Jacob Kalina
Yea, I did. Drove all the way from Missouri to Virginia Beach to pick it up. I only payed $9550 for the car. Only aftermarket parts are a catback borla exhaust and a k&n short ram intake. I did notice a lack of power on the way back home.. but I didnt think nothing of it.. Seeing as how it's my first Z I didnt know what to expect.. but now it's becoming annoying and I dont' want to damage the motor.. if I haven't already
