engine tick/knock
Old May 3, 2012 | 05:13 PM
EnSaYnE-Z33's Avatar
EnSaYnE-Z33
Re-calibrate, would be like just adjusting it to the right setting. Idk that's what the guy at the meet told me. The noise pisses me off so much is making regret the car. -___- I want silence!
Old May 6, 2012 | 07:04 PM
EnSaYnE-Z33
so this weekend i went to 3 different shops. all which told me that i will have to do a valve lash adjustment. im going to do some research about that online. and do this. i have a good feeling this may be it. but i can be wrong. so ill give it a go and let you guys know if it worked or not.
Old May 7, 2012 | 01:02 PM
will350z's Avatar
will350z
keep us posted, I'd love to have some silence!
Old May 7, 2012 | 06:19 PM
Itzcashew's Avatar
Itzcashew
Watch this
http://www.youtube.com/watch?v=XZCRx...feature=relmfu
Old May 8, 2012 | 12:47 PM
will350z's Avatar
will350z
Originally Posted by Itzcashew
awesome post, looks like it's the tensioner then.
Old May 8, 2012 | 03:11 PM
Itzcashew's Avatar
Itzcashew
Here is also the main cause of slack in the timing chains.
http://www.youtube.com/watch?v=QI3xq...feature=relmfu
Old May 12, 2012 | 06:55 AM
will350z's Avatar
will350z
Was there ever a TSB on this?
Old May 13, 2012 | 09:46 AM
black3.5z's Avatar
black3.5z
My engine had a tick in it sounded like it was coming from the head turns out it was the ac belt. I sprayed it with some lube and te tick went away. It was so weird sound just like a valve tick. It's worth checking out.
Old May 13, 2012 | 03:48 PM
Itzcashew's Avatar
Itzcashew
I don't think so. If they did then every VQ out there wouldn't be so damn noisy!
Old May 20, 2012 | 03:44 PM
dubbingt's Avatar
dubbingt
I have the same exact problem with my Z. Been looking for a solution for quite a while now. I listened to mine with a stethoscope and my noise is coming from the passenger side near the front bumper (cylinder 1?) Im not sure if its the lifters or timing chain. Heres a video of a G that had the noise caused by bad lifters. He stated that the lifters were replaced and it sounds fine now. Mine doesnt sound this bad but it sounds exactly like the first video posted.
http://www.youtube.com/watch?v=Umd7cQe7yT4&feature=plcp
Im up for an oil change and will probably put 4qt of mobil 1 syth 5w30 and 1 qt Marvel mystery oil to see if that does anything.
Old Jun 30, 2013 | 05:33 PM
domrvt's Avatar
domrvt
Sorry to bump an old thread, but someone might come along this in a search like I did.
Regarding the timing chain tensioner and the videos linked, it appears the 350Z uses a different setup. Mine doesn't look anything like the one in the video. So if you're chasing a tick, look elsewhere.
Old Jun 30, 2013 | 06:38 PM
theZride03's Avatar
theZride03
i dont think there is any way to recalibrate the chain if the timming chain tenshioners are drivvin off oil pressure the only way is to replace the VTC gears the timming chain and all tenshions i would say its fine as long as the noise goes away my 03 has a slight tap on engine startup all the time i think the Z had a design flaw that it starvs oil at cold starts. if you keep your oil clean and your oil pressure is good your gold my friend my z has 193k miles and still going strong i noticed that tap around 120k miles on mine.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
