car shakes on highway
Old Apr 29, 2012 | 12:01 PM
pistols07Z's Avatar
pistols07Z
Default car shakes on highway
Drove the Z on a Sunday morning. Parked it, when I got home from work Monday evening I noticed the rear passenger tire was completely deflated sitting on the flat.
Filled it with 2 cans of fix a flat to get it inflated enough to drive to local shop to have plugged before closing.
I take the Z to work on Friday and notice violent shaking on the highway about 65-70mph. The whole car, not just the steering wheel. Feels like its coming from the rear passenger side where the flat tire was.
Took it to the shop to get the rears balanced. Drive home and same shaking happens. So I bring it back and they re-balance the tires saying "a weight fell off". I drive home and instead of the shaking starting at 65-70mph, it moves to 70-75mph. I call the shop back and they recommend me to another location that has the road force balancer. After balancing with the road force balance, I drive home only to notice the shaking was pushed back till 80mph.
Shop is telling me I need to replace tire that was flat. Saying the internal belt could have been damaged from sitting deflated for over a day. The tires are 3 months old, only driven on the weekends.
Should I replace tire or could it be something else?
Old Apr 29, 2012 | 12:09 PM
KornerCarver's Avatar
KornerCarver
I suspect you problem may be caused by the Fix a Flat. I think that puts a rubbery solution into your tire and it could have hardened in one spot, making the tire out of balance.
Old Apr 29, 2012 | 12:11 PM
pistols07Z's Avatar
pistols07Z
That makes sense. Maybe two cans of it, back to back got a nice buildup..
Old Apr 29, 2012 | 02:02 PM
Josh|Swag's Avatar
Josh|Swag
Are you getting any sort of reimbursement for aligning your car 3 times with no positive outcome?
Old Apr 29, 2012 | 03:28 PM
JCITY's Avatar
JCITY
Had a similar situation with Fix A flat several years ago(not a Z).
This stuff will act like a weight in your tire and throw off your balance.
Get your tire removed and cleaned out.I pity the guy doing this.Its gonna
be one sticky mess.Get the assembly rebalanced and see what happens.
Old Apr 29, 2012 | 04:21 PM
beezee's Avatar
beezee
Op said "balanced" not allignment. They are not the same thing
Old Apr 29, 2012 | 04:56 PM
Agree. Take the wheel-tire apart and look at the result of Fix a Flat. You will never touch this junk again.
Old Apr 29, 2012 | 05:12 PM
pistols07Z's Avatar
pistols07Z
car was getting balanced, not aligned. they were free of charge since i bought my tires from this shop.
Old Apr 29, 2012 | 05:15 PM
jduet's Avatar
jduet
What caused the flat?
Old Apr 29, 2012 | 05:18 PM
pistols07Z's Avatar
pistols07Z
Small/Med size nail in center of tread.
Old Apr 29, 2012 | 06:30 PM
bmccann101's Avatar
bmccann101
also eats the material of your wheel and the coatings off.. its nasty stuff... never ever use fix a flat. Its an emergency fix only.
Old Apr 29, 2012 | 06:55 PM
R350Zz33's Avatar
R350Zz33
what dumb *** uses fix a flat use the spare and patch it urself then again last time i got a flat every gas station i went to only sold fix a flat no plugs. next time keep a plug kit in your car i do and all my friends who ride bikes to its cheap insurance to the hell you are about to see when they take that tire off
Old Apr 29, 2012 | 07:15 PM
pistols07Z's Avatar
pistols07Z
It's only been a few days. Should I ask to demount tire and remove gunk, rebalance. Or just replace tire?
Old Apr 29, 2012 | 09:23 PM
SuperBlack350z's Avatar
SuperBlack350z
any reptuable shop will know that the fixaflat in it is causing the balance problem. fix a flat does not dry easily so it will be chasing weight when they are balancing ..meaning, the fix a flat in the tire will be sliding around inside the tire throwing off where the weights need to be placed on the wheels.
also check for any type of wear of heat rings when you had a flat tire, that could cause a bad tire not feeling smooth.
Old Apr 29, 2012 | 09:39 PM
RMichael's Avatar
RMichael
really?
Old Apr 30, 2012 | 07:14 AM
drivessidewayz's Avatar
drivessidewayz
What everyone else is saying; fix a flat brokt your tire. If you got a road hazard warranty with your tires, then it should be covered. If you didn't, then you're sol. I have never attempted to clean fix a flat, so feel free to share the results of your endeavor. However, take this as a learning experience never to use it again.
Old Apr 30, 2012 | 03:03 PM
pistols07Z's Avatar
pistols07Z
Just had the tire removed from rim and they pulled me in the back to show me the tire full of liquid up to about half the sidewall... Getting cleaned up now. Hopefully this will do it.
Old Apr 30, 2012 | 03:25 PM
pistols07Z's Avatar
pistols07Z
Well no more shaking
Old Apr 30, 2012 | 09:48 PM
R350Zz33's Avatar
R350Zz33
Duhh
etkms
Jun 19, 2022 06:30 PM
kyin
Sep 29, 2015 06:57 AM
Darkspy
Sep 7, 2015 09:09 PM
