Need help - PERFORMANCE LOSS-
Old May 4, 2012 | 04:47 PM
can84's Avatar
can84
Default Need help - PERFORMANCE LOSS-
I m living in Qatar and driving 350Z. I bought it 4 months ago. its 2008 model A/T. my problem is, 1 month ago my car starts misfiring. I changed the spark plugs and it stops. 6000 miles later it starts misfiring again and i went to an express service and we checked the cylinders and number 4 and 5 was misfiring. I changed the ignition coils for those cylinders. Now my car seldomly misfiring when i start the engine for 30-40 seconds. It doesn't matter if the engine is cold or warm, it misfires. And Sometimes i feel performance loss like 1 second slower then before when i try 0-100, and also 100-200 it is much slower then the normal performance. My car is stock, no modifications. Do you have any idea that what might cause that problem ?
Old May 4, 2012 | 08:05 PM
R350Zz33's Avatar
R350Zz33
Coil packs hooked up in the right order ?
Old May 4, 2012 | 08:40 PM
can84's Avatar
can84
I think so, process done in Nissan Service.
Old May 4, 2012 | 11:22 PM
Itzcashew's Avatar
Itzcashew
Hmmm timing related? Check valve shims?
Old May 5, 2012 | 06:02 PM
R350Zz33's Avatar
R350Zz33
cause they know what there doing there right
Old May 5, 2012 | 10:13 PM
can84's Avatar
can84
well, they know better than me for sure what should be the order ?
Old May 6, 2012 | 02:54 AM
R350Zz33's Avatar
R350Zz33
Idk but you should never trust the stealership they only care about ur money not u did the problem occur shortly after there work ?
EnjukuRacing
Sep 30, 2015 06:55 AM
Tochigi_236
Sep 27, 2015 03:40 PM
