05 350z Touring - HID problem - Plz help :(
Old May 5, 2012 | 08:44 PM
Colourdeaf's Avatar
Colourdeaf
Default 05 350z Touring - HID problem - Plz help :(
Today after washing my car i turned on my HID's that came oem stock when purchased from dealership and they worked fine, drove to meet friends then turned the car off and then after I got back into my car and turned them back on and only the passenger side low beam HID headlight is working,
I checked all fuses in the * secret * fuse box and took out the low beam fuse relay and then the passenger side stopped working aswell, inserted it back in and changed the drivers side bulb and still only the passenger side is working.
my question is wtf is wrong and is the low beam driver side connected to its own relay and the passenger side to its own relay ?
do you believe its the ballast ? the driver side ballast does not make any noise when i turn on my headlights
The wires look to be all connected, ALL other lights work in the drivers side headlight, including turn signal and the high beam
Old May 5, 2012 | 09:54 PM
Troubleshooting is a pain in the *** because you must find the hot wire, then follow it with a continuity tester. If you get a no go on the tester, you know that the problem is the component before the failed point.
Old May 5, 2012 | 10:02 PM
Colourdeaf's Avatar
Colourdeaf
I'll swap the ballast and see if then it works, i've never took the time to purchase one of these electric things
Chris350z03
Oct 8, 2023 07:19 PM
pslamp32
Feb 8, 2017 09:07 AM
issyz
Sep 10, 2015 02:00 PM
