z hatch alignment off
Old May 16, 2012 | 06:43 PM
ZDominicZ's Avatar
ZDominicZ
Default z hatch alignment off
ok, so I just bought a 2003 350z that has been in a small rear end accident, in which the bumper and the left quarter panel was replaced. I noticed that the hatch is not properly aligned. there is a gap between the hatch and the roof, and the hatch is hanging off of the rear bumper. Is there any way to adjust the hatch? or could it be a different problem?
Attached Thumbnails z hatch alignment off-p1060439.jpg   z hatch alignment off-p1060441.jpg   z hatch alignment off-p1060442.jpg
Old May 16, 2012 | 08:46 PM
Waiz's Avatar
Waiz
I would start with adjusting the hatch struts
Old May 16, 2012 | 10:25 PM
The problem is the bumper and the left quarter panel was replaced. Shoddy workmanship.
Old Sep 8, 2022 | 03:57 PM
AR-Finesse's Avatar
AR-Finesse
Default Hatch alignment issues fixed
The solution is to remove the struts and loosen hex nuts on the hinges following up with removing the locking latch now at this point you should have your hatch down and someone to push forward apply pressure to get proper alignment so that you get back inside the car to re-tighten hex nuts on hinges then reassemble you should be OK
Old Sep 8, 2022 | 04:37 PM
dkmura's Avatar
dkmura
General & DIY Moderator
You're responding to a post that's over a dozen years old.
ZSpectrum
Jan 27, 2014 04:44 PM
CottonWoodz
Jan 19, 2003 04:21 AM
rcamooso
Oct 16, 2002 06:45 PM
