350z engine
Old May 26, 2012 | 10:10 AM
hand_brake's Avatar
hand_brake
Default 350z engine
Pulled a vq35de rev up engine from a Z that was damaged. Seems like there is some plastic on the driver side of the engine that cracked and what looks like coolant leaked out.
Is this replaceable? It isn't visible in this picture but that is the location where it is.
I don't have the actual pic but the plastic is black color. I hope to take an actual pic as to better describe the part.
Thanks for your help.
Old May 26, 2012 | 10:39 AM
Itzcashew's Avatar
Itzcashew
First of all this thread is in the wrong place, you put it in the 370z section.
Second of all that black plastic thing is called the valve cover/rocker cover. There should not be any coolant coming out unless one of the hose around it is damaged.
Old May 28, 2012 | 08:45 PM
hand_brake's Avatar
hand_brake
Sorry for posting in wrong forum.
Is this fixable?
And a $$$ figure estimate would be great.
Old May 30, 2012 | 06:56 AM
hand_brake's Avatar
hand_brake
Anyone ever had to repair this part of the engine?
Old May 30, 2012 | 10:11 AM
Itzcashew's Avatar
Itzcashew
That metal pipe is a coolant pipe and the black plastic is the rocker cover.
Try courtesyparts for the replacement of those two. It will be quite the amount of money because you will need to replace the other hand side and the gasket.
Also do you know if the engine still runs? Because it looks like its damage to the block too...
Old May 30, 2012 | 10:15 AM
hand_brake's Avatar
hand_brake
No clue if it runs. Side damage, couldn't reach the clutch to try and start it.
Now its pulled, any way to find out if it would still crank?
Old May 30, 2012 | 11:11 AM
Itzcashew's Avatar
Itzcashew
looks like the motor is toast. The O2 sensor is snapped off and the valve cover bolt direct above it is pointing a diff direction than the others. Only way to really tell is to take the motor apart to assess if there is any internal damage.
Old Dec 4, 2012 | 09:18 AM
hand_brake's Avatar
hand_brake
I started taking the cover apart and I really can't tell if the inside is damaged. I am going to try and take pictures of what it looks but I am going to part this engine out.
Old Dec 4, 2012 | 11:41 AM
oldschool350z's Avatar
oldschool350z
Sounds like it has internal damage. Hopefully you got it for a good price..
Old Dec 6, 2012 | 07:11 AM
hand_brake's Avatar
hand_brake
I'm no exert bu doesn't look like anything is bent.
_koubie_
Sep 20, 2015 06:34 PM
