Heater fan problem
Old Jun 15, 2012 | 08:38 AM
privateer's Avatar
privateer
Default Heater fan problem
Hi Guys
07 nismo only 9k miles on it...as you can see i dont drive the z as much a i would like,so i havent driven the car for around two weeks (kept in garage) drove it to work today turned the AC on full there as a hell of a noise coming from the fan,drumming noise vibrating through the dash, anybody else had this problem? or might know what might be causing it??
Any input would be appreciated.
Thanx
Old Jun 15, 2012 | 08:56 AM
musubi's Avatar
musubi
I'm not sure on the answer, but you might want to try asking around in other sections like Maintenance & Repair. Since this issue is probably not related to Nismo components on the 350Z Nismo, I doubt many people in this section would know.
Searching found me this:
https://my350z.com/forum/maintenance...fan-noise.html
This may or may not be the answer, have you searched the forums?
Last edited by musubi; Jun 15, 2012 at 09:00 AM. Reason: EDIT: Noticed the thread was moved from the Nismo to here.
Old Jun 15, 2012 | 10:05 AM
privateer's Avatar
privateer
Default easy fix
the noise was buggng me so much, i found out the fan was just under the dash passenger side not even covered up took the 3 screws out fan dropped down low and behold the thing was filled up with felt,i guess it was sound deadner,
job done took 10 minuets
woot
Uriyo_
Sep 8, 2021 08:46 AM
