car sputtering
Old Jul 25, 2012 | 07:36 AM
too_slow350z's Avatar
too_slow350z
Default car sputtering
yes hello, how is everyone doing? i have a little issue. my car turns on perfectly and everything works fine, but when i drive the car it wont rev past 4500 rpms.. people have told me it the maf sensor. so i changed it out still problem... brought it to nissan and they told me it could be bad cats... so my issue is, would bad cats cause my car to sputter like its redlining? please any input would be greatly appreciated.. thanks in advanced
Old Jul 25, 2012 | 09:11 AM
cubs4worldseris's Avatar
cubs4worldseris
Have you reset the ECU? Done the Throttle Position Sensor relearn procedure? Adequately maintained your car to date? Pulled the cats off to visually inspect them yourself?
These are are very basic things I would do before considering dropping hundreds of dollars on new OEM cats. If it is your cats, you may want to look at buying a used set, buying new test pipes, or high-flow cats.
Old Jul 25, 2012 | 09:49 AM
silverbullet_Z's Avatar
silverbullet_Z
What he said. Plenty of people on here who change out their cats for either HFC or Test pipes.
Old Jul 25, 2012 | 02:13 PM
JCITY's Avatar
JCITY
Car showing CEL/codes?
Old Jul 25, 2012 | 05:36 PM
too_slow350z
i had somedude check for me, cleared the code anddidnt tell me what it was... now i cant find him... nissan checked diagnosis and cudnt find code.....they told me to pay extra 135$ ontop of the 115diagnosis fee to check the cats... now im****ied (excuse language) idk what to do now
Old Jul 25, 2012 | 05:40 PM
too_slow350z
and yes iv mantained it real well, so did previous owner
Old Jul 25, 2012 | 05:50 PM
Barnabas's Avatar
Barnabas
National Z Club President
Sounds like its in limp mode... i dont think the cats would do that...
Any signs or symptoms prior to this like any idea what triggered it?
NEW MAF when you replaced it? be careful to not touch sensor? Drive through any rain/puddles??
Old Jul 25, 2012 | 05:51 PM
Barnabas's Avatar
Barnabas
try unhooking battery, pump brakes 5-10 times, rehooking battery up and see what it does... drive easy the first few miles then slowly push it harder, see if it goes into limp again or if a code appears
Old Jul 25, 2012 | 08:15 PM
too_slow350z
OK I will try that tomorrow morning... and it started after i installed intake
Old Jul 25, 2012 | 08:26 PM
Barnabas's Avatar
Barnabas
What intake?
Sounds most certainly like a wet MAF or contaminated making the car go into limp mode.
My car used to do it when I was NA when i drove the car hard when it was wet outside. Did it start doing it once you pushed the car? or even when driving it easy?
Old Jul 26, 2012 | 04:31 PM
too_slow350z
i got the intake as a gift, idk name... but some1 told me the maf cud have gone wrong... i got new one, put it on and still same problem.... some1 told me it could be in limp mode.... and yes it does happen when i push it a little... and normal driving too and wen im in neutral. once it gets to 4500 rpm and it sputters.... and how exactly do i have to do to get it out of limp mode....
Old Jul 26, 2012 | 04:45 PM
RMichael's Avatar
RMichael
It's got to be showing a code. Start by checking the code. Yeah I get your buddy cleared it without telling you but that won't make it go away without fixing the issue. It does sound like limp mode like stated earlier but hell, Pep Boys will tell you the code for free if you can't pull the OBD-II codes.
Old Jul 26, 2012 | 04:53 PM
RMichael's Avatar
RMichael
https://my350z.com/forum/intake-exha...limp-mode.html
Old Jul 27, 2012 | 04:41 AM
Barnabas's Avatar
Barnabas
^whs
Old Jul 27, 2012 | 07:38 AM
too_slow350z
there is no code... my cel is off, the guy cleared it so no codes show up... im goin to try the unhooking battery cable and pumping brakes 5-10 times after work. i was goin to do it yesterday but a freak storm hit my area so i wasnt able to do it. ill try it later on and post up my results on here
etkms
Jun 19, 2022 06:30 PM
pslamp32
Feb 8, 2017 09:07 AM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
