2003 350z burned up wire harness
i have a 2003 350z for which most all of the wires under the hood and some under the dash are corroded and melted. i'm trying to pull the entire wire harness under the hood out of the car. i've disconnected every connector in the car and am having trouble pulling the harness through the dash wall and behind the engine to get it out of the car. i have the ability to repair the harness, but need to know how i can get the harness out of the car. i've removed the entire dash and am lost under the hood. should i remove the brake lines at the master cylinder ? is there a trick to get this harness out of the car. please help!!!!
jocksivs@gmail.com or 214 200 1569 all advice is welcomed
thank you
thank you
SpartanZ32
10-22-2015 09:36 AM
