Grind Diagnosis
Old Aug 26, 2012 | 10:18 AM
RENFRO's Avatar
RENFRO
Default Grind Diagnosis
Sup guys, been doing some reading and having a random issue.
Background: '03 Track model. Original Transmission. 64k miles. Redline MT-85 Fluid swapped about 6k miles ago.
I've noticed a grind when shifting from 2nd to 3rd. It's not every time, but usually if I don't give a slight pause when going from 2nd it will grind...but sometimes I can get on it and shift from 1-2 at about 5k rpm...and then 2-3 at 5k rpm very snappy and quick and no grind.
Today, just to see what happened, I sat still (0mph) and idle rpms...pushed the clutch in and went straight into 3rd gear...grind. did it again, but pushed clutch in, waited one second and then into 3rd. no grind.
I'm somewhat dumbfounded. Synchro issue? That was my first diagnosis...the grinding comes and goes.
I've already starting pricing a CD009 tranny with new clutch/flywheel while I'm at it, but wanted to get some opinions on the symptoms before I dump money into it.
For now I'm continuing to drive it until I can get a solid diagnosis.
Thanks
Old Aug 26, 2012 | 11:09 AM
Looch's Avatar
Looch
Third gear synchro, join the club
Old Aug 26, 2012 | 12:31 PM
RENFRO's Avatar
RENFRO
Yeah I figured as much. Guess I'll just baby the 3rd gear shifts until I can get some $$ for the CD009 and clutch/flywheel.
lolwatbro
Oct 9, 2021 04:58 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
BlinkerFluid
Sep 8, 2015 10:06 AM
themyst
Apr 26, 2003 04:05 PM
BYOB
Apr 17, 2003 07:19 PM
