Gauges don't work
Old Sep 12, 2012 | 06:58 PM
Projectblak's Avatar
Projectblak
Default Gauges don't work
Sorry if this is in the wrong section, seemed most suitable to place it here.
2004 350z
First off it is not my car. So here is the story someone breaks into this z and steals the radio but decides he should cut the whole radio harness.. Gauges light up but the needles don't move.. The triple cluster works fine, but the tach, speedo, temp, and fuel gauge do not.. We replaced the entire dash harness with a brand new oem Nissan one.. Factory radio has been re-installed.. Cluster lights up and all the warning lights come on as well as the fuel light but the needles dont move.. I have checked all the fuses and no dice there.
Any input is much appreciated.
Old Sep 13, 2012 | 12:59 AM
dj lizard's Avatar
dj lizard
did you check the radio harness if it was connected properly.. I have seen that happen in my car when I started it up cuz I had to move it from the garage.. I reconnected the harness properly and everything went fine... try to check to BCM, ECU and the fuse box in the engine bay as will.. if it don't work then I give up lol...
Old Sep 13, 2012 | 02:20 AM
Projectblak
thanks for the reply, i will pass ur ino to him and see what happens.
Old Sep 13, 2012 | 02:48 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Check the harness and wires to/from the AC module (white box under the stereo). I had this happen a few years ago:
https://my350z.com/forum/exterior-an...t-working.html
Old Sep 13, 2012 | 03:11 AM
KingBaby's Avatar
KingBaby
Hardest Setting
check everything ahahahaha
Old Sep 19, 2012 | 07:32 AM
Projectblak
Advanz33 you was right it was the little AC module replaced and now working again! thanks
Old Sep 19, 2012 | 08:06 AM
AdvanZ33's Avatar
AdvanZ33
Glad my expensive dealer trip can help others save some dough
Old Apr 9, 2014 | 08:30 PM
ispiff's Avatar
ispiff
Thanks man! Your input saved me from going crazy!
Old Apr 10, 2015 | 08:10 AM
Don Weddle's Avatar
Don Weddle
I have a similar issue with gauges not working but my dash lights do not work either. However my oil pressure and batt gauge does work. Is this still an issue with AC module
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
Calinismo350z
Sep 14, 2015 04:04 PM
