Anti-freeze consumption
Old Sep 28, 2012 | 05:19 PM
T_R's Avatar
T_R
Default Anti-freeze consumption
Hey whats up guys, i have a 2003 350z i bought it with 55k on it and its been a year and12k later. When i bought it was low on anti-freeze in the resevoir so i filled it up. Through out the year i have done this a total of 3 times, last time i filled it was about 2-3 months ago and today it was low agian. But the thing theres no sign of leaking from what i see. My mechanic says its prob a small leak in the intake gasket or head gasket? Idk what to do, from what my mechanic tells me if its the head gasket i should sell the car. But i have to much money into the car. Any help Please?
Old Sep 28, 2012 | 05:27 PM
Tomek350Z's Avatar
Tomek350Z
check the condition of your oil. Coolant mixed with oil will create a milky like substance if contaminated. Also if that does not solve it the next step would be to pressure test the cooling system. if your handy then you can pick one up from sears and do it yourself. Last, while driving, does your car emit white smoke? because when coolant is burned it creates a thick white smoke from the exhaust.
Old Sep 28, 2012 | 08:20 PM
T_R's Avatar
T_R
Well my friend drove my car the other day and wasnt fully warm and pushed it kinda hard and there was a tiny bit of white smoke but nothin bad, also nothing on the normal basis. Btw i have test pipes, stillen exhaust and intake. Also i just changed my oil today and i didnt really check the oil condition. What i also really want to know is should i put off on installing my new kinetix v+ plenum, because once i put it on and have to remove it ill have to send it in for re-gasket service? And is it safe to drive, on the normal basis it drive great?
Old Sep 28, 2012 | 09:18 PM
Tomek350Z's Avatar
Tomek350Z
well at this point if it truly is a 'small' leak then I would go about performing a pressure test on your cooling system. If that doesnt yield results, the next step would be a cylinder leak down test. On a side note if you are burning coolant, there will be a sweet smell to it, but considering the fact that you have TP's it would be hard to tell. Do you have any CEL's present? normally coolant that enters the exhaust would contaminate your oxygen sensors, but this could take some time considering you say that it is a small leak.
Old Sep 29, 2012 | 08:26 AM
T_R's Avatar
T_R
i caint really tell the smell from yhr exhaust because of my test pipes, and theres no cel. if i do a pressure test wouldnt that cause the leak to get worse in which case if its the head gasket, its a bigger issue?
Old Sep 29, 2012 | 10:12 AM
Tomek350Z's Avatar
Tomek350Z
well the purpose of the pressure test is to see if the system truly is leaking. it wont hurt anything because you areonly applying about 10 psi to the system. The whole point is to build pressure and see if it holds. If it does not you can start looking around to find a leak. The benefit of this is that it might only leak when under pressure. If that does not solve anything you can do the leak down test. something simple you can do at the moment is to leave your radiator cap of whilethe motor is running for a few mins and see if there are air bubbles passing through. That would indicate combustion cylinder pressure is escaping into your cooling system, indicating a bad headgasket somewhere.
Old Sep 29, 2012 | 10:18 AM
DaveJackson's Avatar
DaveJackson
Master
You can check the condition of your oil by simply looking at the bottom of the filler cap. If it looks like someone spunked in the oil on the bottom of it, you probably have a bad head gasket.
Coolant leaks can be very difficult to find. Pressurizing the system and getting under the car (remove under-shroud first) makes it easier to find the leak. It sounds like it will be quite tiny.
Old Sep 29, 2012 | 03:13 PM
T_R's Avatar
T_R
Thanks for all ur help guys, so i havent done apressure test yet but i did do the test where u check for air bubbles with the cap off and there were no bubbles. For now i filled up the resevoir to the max and will keep check for a couple weeks. I will try to do a pressure test soon. Also got the supplies for a coolant flush which ill do next week. The coolant was kind of dirty when i did the bubble test.
Old Sep 29, 2012 | 03:16 PM
T_R's Avatar
T_R
The oil cap is clean, its starting to seem like a tiny pin-hole type of leak to me.
Old Sep 29, 2012 | 03:17 PM
T_R's Avatar
T_R
Btw i really really want to install my new plenum. Do u guys think i should go ahead with it or wait a bit, because if i have to remove it for some reason ill have to send it in for a regasket service. Thanks
Old Sep 30, 2012 | 04:22 AM
Cass007's Avatar
Cass007
Either be prepared to spend the money on the regasket service or act like and adult, have some patience and see if you lose coolant again. It seems to me that you know you have an issue, but instead of heeding your mechanics advice or getting the tests done to find the problem you are intent on putting on the Kinetix (POS) so you can raise the hood and show your friends your cool new mod.
Old Oct 1, 2012 | 07:59 PM
T_R's Avatar
T_R
Ok so im holding off on the plenum, i was just excited about the new part and it was the last bolt on part before i was getting it tuned. But back to the issue
its been about 3-4 days and 500 miles and the coolant level is the same, so far its good.
Old Oct 1, 2012 | 10:19 PM
Tomek350Z's Avatar
Tomek350Z
good to hear, keep us updated
Old Oct 2, 2012 | 10:32 PM
T_R's Avatar
T_R
Will do, Thanks for your help.
Old Nov 16, 2012 | 05:38 PM
bjr's Avatar
bjr
I know that this may sound VERY stupid but I feel like there are more details that need to come or I may have missed a clue. So in the mean time have you simply tried replacing the radiator cap?
A faulty/worn cap will allow coolant to escape looking like a leak (low on coolant).
allmycarsdie
May 13, 2016 04:38 PM
Bigsyke
Sep 11, 2015 06:19 PM
overZealous
Jan 16, 2005 06:52 PM
yobri
Mar 11, 2004 08:28 AM
