03/have to use hrottle to start after warm up?
Old Sep 29, 2012 | 09:07 AM
Rocket69's Avatar
Rocket69
Default 03/have to use hrottle to start after warm up?
my 03 , automatic starts and idles fine cold but after it warms up it will start and die unless you give it gas? runs fine all the time otherwise, any suggestions????
Old Sep 29, 2012 | 09:36 AM
DavesZ#3's Avatar
DavesZ#3
Do anything to it recently?
You can always try the throttle re-learn procedures...
https://my350z.com/forum/6008226-post2.html
Old Sep 29, 2012 | 09:51 AM
Rocket69's Avatar
Rocket69
I haven't , but it has sat for about a year without driving much. I will try that,
thanks !
Old Sep 29, 2012 | 01:45 PM
terrasmak's Avatar
Yup, mine has been like that for years, happened after a test pipe install. Still happens with stock cats , HFC etc etc. gave up on it.
Old Sep 29, 2012 | 04:01 PM
Rocket69's Avatar
Rocket69
tried resetting the throttle, no luck. Any other suggestions???
Old Sep 29, 2012 | 06:46 PM
tony530's Avatar
tony530
Sounds like a vaccum leak?? check out ur vaccum hose.
Old Oct 2, 2012 | 02:00 PM
Neimad's Avatar
Neimad
Possibly there is a light on the dash that has been on for awhile indicating the engine needs servicing?
Old Oct 4, 2012 | 08:06 PM
Rocket69's Avatar
Rocket69
Car had no codes or lights. The good news is here was the fix:
removed the throttle body and throughly cleaned the throttle body.
***make sure not to push on the flap in the throttle body, it will break the mechanical/electrical mechanism and you will be replacing your throttle body assembly***
I didnt do this but a friend of mine did.
thanks
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
Dymsi
Sep 29, 2015 11:32 AM
