No Clutch Pressure After Slave Change And Bleeding
Old Oct 14, 2012 | 06:00 PM
TheWoods's Avatar
TheWoods
Default No Clutch Pressure After Slave Change And Bleeding
Hey guys, I searched search and search and tried every method, still no dice. I just replaced my slave and bleed the system. At first it wouldn't bleed. Then I adjusted the pedal adjuster screw and its started peeing like a race horse. But after that, still no pressure. I even bled from the master. Did vacuum bleeding, old school bleeding, said a prayer to God, I even cut my self to see if that would bleed.
Now, I still have zero pressure EXCEPT at the very bottom.
Any ideas?
Old Oct 15, 2012 | 02:58 AM
bmyles's Avatar
bmyles
Might have to do with adjusting the clutch pedal. Put it back to where it was and see what that does.
Old Oct 15, 2012 | 10:55 AM
TheWoods's Avatar
TheWoods
That had nothing to do with it. It was adhusted way down because the pedal was so loose. So I pretty much unscrewed the adjuster so the pedal would come all the way up, thus opening the master all the way.
Issue is now resolved. All I did was pump the pedal like a Vegas ***** and every is peachy.
/thread
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
