Repairing the underside of a CF hatch
Old Oct 30, 2012 | 02:00 PM
puertorican's Avatar
puertorican
Default Repairing the underside of a CF hatch
I purchased struts from a vendor here who specified struts were made for CF hatch, long story short they didn't work out well for me. Throughout time the strength of the struts pushed my hatch back. What I mean by that, it created a gap between roof and hatch. As result the hatch is damaged near the hinges and mounting points. I read a while back of someone creating a brace to evenly distribute weight. So my question is.....
Can the underside (not top cf) be repaired by simply reglassing? Does anybody have info to link of the brace created? Any suggestions? I really don't want to trash this hatch. Any help will be greatly appreciated.
Old Oct 30, 2012 | 02:16 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Since you started a thread about this, I'll re-post this email for future reference to hopefully avoid future occurrences:
"as for insight on any Carbon hatch, i recommend you run to home depot and purchase some skinny fender washers. They are thin wide washers that you can install the on the HATCH side when installing the ball stud.
this i recommend to help distribute the weight transfer of the hatch shock force to the carbon hatch.
see all the carbon fiber hatches use a threaded insert that is simply glued in during the manufacturing process of the carbon fiber hatch. the factory hatch has a welded nut inside the hatch, any carbon hatch uses a glued in threaded insert...
so adding a large washer i feel helps distribute the load a bit better. I cant say its needed, but if anything its a good precaution.
i have friends and customers that have gone with and with out it and been fine."
Old Oct 30, 2012 | 08:31 PM
puertorican
Did you ever find that thread you mentioned that Chebosto posted?
Old Oct 31, 2012 | 04:18 AM
AdvanZ33's Avatar
AdvanZ33
No sorry, I've been searching. Maybe I imagined it or read it wrong. He did mention aluminum brackets in the CF hatch thread I started but that's all I could come up with.
Old Oct 31, 2012 | 11:28 AM
puertorican
All good bro. I will keep doing research. Apparently, the email you posted up still would not have been able to prevent this from happening. All damaged caused by struts was while hatch was close. I'm guessing the strength in the struts would push hatch back,cracking/ separating from mounting points. So pretty much washers or no washers, because of the struts used, damage was bound to happen. I hope you have a better experience with them.
Old Oct 31, 2012 | 11:34 AM
AdvanZ33's Avatar
AdvanZ33
Damn, me too. What type of hatch do you have?
Old Oct 31, 2012 | 03:04 PM
puertorican
I have the Mastergrade CF hatch
Old Oct 31, 2012 | 03:43 PM
AdvanZ33's Avatar
AdvanZ33
Of all the the CF hatch threads I've read on here (which is probably all of them) people say the Mastergrade hatch is much lighter than all the rest but there's a reason for that - less material. One member had the same issue as you and just took the shocks off afterwards.
Old Oct 31, 2012 | 09:12 PM
terrasmak's Avatar
I would use worn out stock struts.
Old Nov 1, 2012 | 06:22 AM
Voboy's Avatar
Voboy
^-tried it with shocks that needed help lifting my oem hatch... and only on one side. It was strong enough to lift it fine but when closed if was too strong to seal evenly.
Its a little tedious but now i just lift by hand and use something to prop it up. Then again its not a daily.
Old Nov 1, 2012 | 06:35 AM
Voboy's Avatar
Voboy
Op, to answer ur question. Yes a body shop could fix it back up for you.
I found this though:
http://www.350zhatchshocksandmore.com/CARBONFIBER.htm
Did you use that?
Old Nov 1, 2012 | 11:47 AM
puertorican
Thanks for the info guys. I definitely plan on getting rid of the struts and just find something to prop the hatch up. I'm waiting for a few more parts to get here before I go back to the shop, but from the information I found on here and other forums, I have peace knowing this CAN be replaced. From what I gathered, damaged area needs to be cut out, bracket or sheet metal used to connect hatch and mounting points, then reglass the area. I'm gonna have him glass the hell out of that area, not to concerned on the presentation just as long as it works lol
Old Nov 1, 2012 | 11:48 AM
puertorican
Lol ya i believe those are the struts I used
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
dcains
Sep 21, 2015 09:28 AM
dragon11689
Sep 7, 2015 02:47 PM
