Engine Knock/Tick after SeaFoam
Old Nov 3, 2012 | 06:47 PM
Get Scared's Avatar
Get Scared
Default Engine Knock/Tick after SeaFoam
Hey guys, I just bought a 2003 350z with 135k miles on it. Right after I bought it the Service Engine Soon light came on, I had it checked out and it turned out to be a misfire on plug #1. So today while waiting to put new plugs in it I decide to seafoam the car via the vacuum line. I put about 1/3 in the line very slowly and 1/3 in the gas tank. Soon after I began to hear a knock while the car was in neutral with the clutch out, however if I push the clutch in the knock/ticking noise goes away. Any idea what could be causing this? Could it just be the spark plugs or maybe the input shaft bearing? Any input is very appreciated.
Old Nov 3, 2012 | 07:15 PM
Rokyr's Avatar
Rokyr
Track down exactly where the ticking is coming from. If tranny, it's probably throw out bearing. Mine makes the same tick when it neutral after it's been driven for more than 10 minutes.
Old Nov 4, 2012 | 04:40 AM
djamps's Avatar
djamps
If it's gone with the clutch in it's probably just the gear lash in the transmission acting 'normal'. If you have a misfire it's going to be worse.
Old Nov 4, 2012 | 05:16 AM
PunkinDave's Avatar
PunkinDave
Throwout bearing.. Mine does the same when first started.
Should go away once the car is driven...
Old Nov 4, 2012 | 05:19 AM
oldschool350z's Avatar
oldschool350z
Throw out bearing is very common on the z. I personally have had that sound since i bought the car with 30K miles now at 45K.
I think it's not going to hurt the clutch or tranny but be very annoying.
Old Nov 4, 2012 | 10:38 AM
QuintonC's Avatar
QuintonC
I bet it's the throwout. Mine was awful, and when you turn the car off with the clutch it sounds like you're murdering a duck. But I just upgraded to JWT clutch and flywheel and it's now gone.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
