Transmission or Throw out bearing?
Old Nov 10, 2012 | 08:46 AM
Pholicious's Avatar
Pholicious
Default Transmission or Throw out bearing?
When the car is at idle the car makes whining and rattling sounds is this from the transmission or the throw out bearing?
Asking around locally I'm told TOB but reading on the forums it can't be the TOB.
The car makes the sound when in neutral and clutch out the sound goes away 100% when clutch pedal goes in.
Old Nov 10, 2012 | 10:54 AM
Gunsmoke's Avatar
Gunsmoke
Normal noises for the Z. Its been covered 1000x its either the throwout bearing (common) or the dual mass flywheel (common) Mine does it as well as everyone else's, sounds like rocks rattling around. Search clutch noise and you'll see tons of threads, with end results being its normal.
Old Nov 19, 2012 | 04:43 PM
tryit350's Avatar
tryit350
Throw out bearing..100%
I just did my clutch and my tob was worn to hell.
Old Nov 19, 2012 | 10:10 PM
cata_mahu's Avatar
cata_mahu
TOB dosen't make noise at idle.
Worn TOB = Noise when you push the clutch in.
Obadabot
Jun 18, 2023 11:31 PM
burglapfd
Dec 6, 2020 01:04 PM
