5AT grind/rattle when accelerating violently
Old Nov 18, 2012 | 04:07 PM
ehaalandtluk's Avatar
ehaalandtluk
Default 5AT grind/rattle when accelerating violently
Hello,
Been trying to get this sorted out in the maintenance forum, but no luck.
I'm having a problem with the noise in my 5AT 2005.
I hear a very harsh grinding noise at the top (5700-6600 RPM) of 1st 2nd and 3rd gear when accelerating with 100% throttle. As soon as I tip the sport shifter it stops and continues with the next gear until I hit the above engine speed again.
It does not happen:
At the top of 1st, half throttle or when maintaining speed.
It DOES happen:
At the top of 1st at WOT
At the top of 2nd and 3rd, half throttle or WOT
Believe it or not I have never hit the top of 4th WOT :S
I've ruled out the differential, the engine, loose objects, suspension so far.
I just changed the fluid to the recommended nissan atf. However this has been happening before the fluid change, as it was a remedial measure.
If I were to say which location the noise is coming from inside the cabin, it would be right below the rear tower bar in the trunk, but that could be due to the extensive sound deadening along the transmission's centerline. I have also taken out my rear spare tire to make sure it wouldn't be worsened and it made no change. (didn't fit over my brakes anymore anyways, lol).
Any help?
Old Nov 19, 2012 | 02:22 PM
superchargedg's Avatar
superchargedg
Damn Noobs
A vid with sound might help
Old Nov 19, 2012 | 03:46 PM
ehaalandtluk
I'll work on that this week.
Old Mar 22, 2013 | 10:20 AM
ehaalandtluk
I'll have to bump this post.
Still having this issue.
Although maybe my hearing has improved/worsened I perceive the noise coming from the engine (which worries me even more)
I tried accelerating the car in manual mode at half throttle all the way through first NO NOISE
SHIFT AT 6800
I tried accelerating the car in manual mode at half throttle all the way through second NO NOISE
SHIFT AT 6800
I tried accelerating the car in manual mode at half throttle all the way through third until I got paranoid looking for cops NO NOISE
So, this only happens under full throttle acceleration.
Sound like a blender turns on from 5000 RPM - Shift.
What could be my issue?
Old Mar 22, 2013 | 10:30 AM
k6750gsxr's Avatar
k6750gsxr
clutch packs are probably going out. since its only under a load. Is the trans stock ? also how many miles are on it? Also have you checked your fluid ? I know that sounds dumb but you never know. Your tq converter might be running dry.
Old Mar 22, 2013 | 01:23 PM
ehaalandtluk
My stock automatic has 98k on it. I checked the fluid level indicator and it is right above full.
How would I make sure this is the problem without dropping it on a long weekend?
Old Jul 22, 2013 | 03:08 PM
trentor's Avatar
trentor
Any luck diagnosing this? I have an 05 G35 sedan 6MT with the same issue. It's driving me crazy.
etkms
Jun 19, 2022 06:30 PM
pslamp32
Feb 8, 2017 09:07 AM
AbyteZero
Sep 22, 2015 09:17 AM
ti837
Sep 22, 2015 07:46 AM
