Horrible noise after valve cover gasket replacement
Old Nov 26, 2012 | 05:33 PM
Shizz's Avatar
Shizz
Default Horrible noise after valve cover gasket replacement
Hello everyone,
My 2004 350z had been running rough with the same symptoms that it had before the valve cover gasket was changed on the right (driver's side), so I decided to changed the valve cover gasket on the left side. There was a small amount of oil in the middle spark plug well, so i replaced the spark plug boot too. The car was put back together and when it started, the most horrible screeching noise that sounded like metal on metal began just after start-up. I couldn't bear to let the car run for more than a couple seconds. I took everything apart again and found some gashes in the crankshaft area. (Sorry I don't know the specific names of the crankshaft parts) I followed the DIY valve cover gasket replacement thread from here step by step. I also covered the area with a towel, to make sure nothing fell in it. My question is what could have possibly caused that noise? Or the damage? Any help would be greatly appreciated!!
Attached Thumbnails Horrible noise after valve cover gasket replacement-img_0636.jpg
Old Nov 26, 2012 | 05:47 PM
Italianjoe1's Avatar
Italianjoe1
Marks on the cam look normal, there are usually grinding marks between some of the lobes. Not sure what to say about the gouge on the inside of the head.
Old Nov 26, 2012 | 06:08 PM
122554's Avatar
122554
Wrench, socket, screw driver, ???????????
Old Nov 27, 2012 | 07:52 AM
Shizz's Avatar
Shizz
Ok, so besides something falling into the crankshaft area, there is no other reason for the engine to make a metal on metal screeching sound?
Old Nov 27, 2012 | 07:56 AM
0jiggy0's Avatar
0jiggy0
Those are camshafts not a crankshaft. Cam looks normal, but ya that gouge looks wtf. What did you drop in there?
Old Nov 27, 2012 | 09:15 AM
Shizz's Avatar
Shizz
I have no idea! I tried to be careful with all the bolts I took off. I don't even know how to search for whatever could have fallen in there. Anyways, thanks for the help everyone.
Obadabot
Jun 18, 2023 11:31 PM
burglapfd
Dec 6, 2020 01:04 PM
Rev_Night
Nov 7, 2020 06:00 PM
sales@czp
Sep 23, 2019 03:30 PM
ablaine
Nov 29, 2016 10:13 AM
